Refitting heated handlebar grips
aetius
PostPosted: 12:22 - 14 Dec 2009    Post subject: Refitting heated handlebar grips Reply with quote
Hi,
The heated handlebar grips on my R1 slip. I guess, over a period of time the glue holding the grip to the throttle bar has worn.
I'm thinking of pulling off the grips and re-fitting. At the moment, I'm using cable ties and some electricians tape, which doesn't quite give enough grip to the throttle bar and the grip sometimes slips, making acceleration harder on the wrist and forearm.
Do you think I'd need to buy new grips? If not, can anyone recommend a glue to fix them back on?
thanks
PostPosted: 12:30 - 14 Dec 2009    Post subject: Reply with quote
The grips are faily solid on the inside, hence you would need a lot of force to compress them into staying still.
However the glue supplied with them is normally just a cheap Superglue clone. Grab a tube of that and stick them back on..
Martay
PostPosted: 13:56 - 14 Dec 2009    Post subject: Reply with quote
When i bought mine, i didnt come with glue.
I wrapped a small ammount of electrical tape around the bar itself, then pushed and rotated the grip on over the tape. (if that makes any sense!) Before, they were loose and just spun round, but after theyre pretty solid.
Hope that helps
Eat well, poo hard Very Happy
Drives: Cavalier 2.0 16v
lonner
PostPosted: 19:49 - 14 Dec 2009    Post subject: Reply with quote
hi
clean the bars
get the grips nice and hot
then apply glue to the bars (super glue works well) and then set them in the correct position
leave to cool and the job done Thumbs Up
the grim reaper
PostPosted: 14:02 - 15 Dec 2009    Post subject: Reply with quote
I use super glue to do mine, although you have to be quick to slide them all the way on, otherwise you get them stuck halfway. If this does happen, use wd40 and a thin bladed screwdriver to break the glue and slide them off, then try again. Be careful not to flex the grips too much though, as you can break the filament inside.
Grim
Feasty
PostPosted: 14:16 - 15 Dec 2009    Post subject: Reply with quote
When I upgraded from an XR125 to my 650 I also swapped the heated grips. I attempted to use superglue but after several bouts of cold weather and having the grips turned on the glue just gave up and the grips were slipping all over the place.
Instead I bought a tube of heated grips glue from my local bike shop, it's worked well and the grips have been solid ever since... superglue is brill but I'd never use it in damp/wet and excessive hot/cold situations. Thumbs Up
Previous: Aprilia Habana Retro 50cc (beauty), Yamaha SR125 (fell apart), Honda XR125 (nippy little commuter), Honda SLR650 (Geewhizz), Yamaha Diversion 900S (Smoooooth) written off courtesy of a stupid escaped horse.
(7 year gap), BMW F650 (Relaxing ride). Aprilia Caponord ETV1000 (Big and bold). Yamaha FZS600 (got me in trouble too quick!).
Current: Yamaha TDM 900 (Comfy, light but big, power when needed).
aetius
PostPosted: 15:56 - 15 Dec 2009    Post subject: Reply with quote
Thanks for the info guys, will give it a go, cheers
The last post was made 16 years, 205 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.81 - MySQL Queries: 13 - Page Size: 52.27 Kb
