Problem with GS 125 battery draining over time.
tvr321
PostPosted: 01:01 - 17 Dec 2009    Post subject: Problem with GS 125 battery draining over time. Reply with quote
Hi, I have a problem with my GS 125's battery draining over time.
It's not the battery, the battery holds it's charge fine. (Tested)
If I charge the battery right up with a charger, it is usable for about a week. After which the headlight starts to dim and then dies completely whilst I'm going along. All electrics fail to work once battery becomes drained.
If I switch the lights off for a minute or two whilst riding, and then switch them on again, they'll last for around 10 sec, before dying completely again, so the bike does charge the battery, just very slowly.
The lights will not work if the battery is not charged -> Won't run off the alternator.
At first I thought there was a wire earthing somewhere, but I have been all over the wireloom (It's very basic) and found nothing.
Since the lights will not run off the alternator, it leads me to think that perhaps it is not producing sufficient power to charge the battery, but I am no expert so input would be appreciated.
Thanks.
temeluchus
PostPosted: 06:19 - 17 Dec 2009    Post subject: Reply with quote
fully charge the battery. Read the voltage with a meter and it should show 12.5 volts approx fully charged.
Start the bike, and rev it up a bit. Should reach 14.5 volts if the system is charging. If it stays at 12.5 and starts to drop, you either have a wiring fault, dodgy regulator/rectifier or a knackered alternator.
heres a handy guide
https://www.electrosport.com/technical-resources/library/diagnosis/pdf/fault-finding-diagram.pdf
Kal
PostPosted: 08:24 - 17 Dec 2009    Post subject: Re: Problem with GS 125 battery draining over time. Reply with quote
It is possible, the alternator on the CG is not fantastic and there is little spare power on the electrics. Are you doing more afterdark riding, especially on urban roads?
Kal...
tvr321
PostPosted: 22:54 - 18 Dec 2009    Post subject: Reply with quote
Thanks, that link is very helpful.
Another question that is not quite related to the original topic but still concerns the GS 125.
I don't think that the dim/full beam etc system has ever worked properly on my GS. I'd like to know how it should work so I can fix it.
I need GS 125 owners here. I think it involves the key, does it not?
My bike will not start on the key's third notch, however, the light does come on (dipped). If I have the key on the second notch, the bike will start, and with the light switch off, the lights will be off. If I flick the light switch, full beam comes on. So basically, I can't switch between dip and high beam. Not really a problem since full beam isn't all that powerful, but still, I'd like it to work properly.
So how does it work on properly functional GS's?
The last post was made 16 years, 317 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.54 - MySQL Queries: 13 - Page Size: 41.82 Kb
