Network bods - Static IP?
s44678
Guest
PostPosted: 10:23 - 17 Dec 2009    Post subject: Network bods - Static IP? Reply with quote
Router question:
Want to set static local IP for my PC and XBOX because I'm sick of changing the port-forward settings each time they get issued a new IP by the router.
Looked in some guides but they all talk about turning off DHCP and setting the IPs manually. But I want to leave DHCP on as it's useful for my laptop, work laptop mrs' iPhone and when people visit etc.
So is there a way to have DHCP on, but set a static IP for select devices?
It would appear that I can just set my IP on my computer manually to something outside the DHCP range (it's set to x.x.x.2 - x.x.x.100) So just set it to x.x.x.101? But will that even work? It seems too simple?
Last time I tried it nothing would connect (not even to the router) but maybe I did it wrong.
Any help appreciated.
UrbanRacer
PostPosted: 10:28 - 17 Dec 2009    Post subject: Reply with quote
You should be able to assign an IP Address by MAC Address on the router. what router do you have?
You can find the MAC Address of a windows PC by opening the command prompt and typing ipconfig /all
the other devices i can't remember where the mac address is listed but i'm sure it'll be under network settings
T1z3R
PostPosted: 10:34 - 17 Dec 2009    Post subject: Reply with quote
theres no need to mess around with MACs.
you can do exactly as you mentioned in your post. if your router is assigning DHCP addresses in the range 192.168.1.2 - 192.168.1.100 then set your static IP on your PC to 192.168.1.101 and on your abox as 192.168.1.102.
job done.
duck my sick!
UrbanRacer
PostPosted: 10:47 - 17 Dec 2009    Post subject: Reply with quote
You can end up with IP Address conflicts if you do that, although if you give it an IP high up the range its unlikely.
also the router might only accept connections from IP Address that have been dished out by the DHCP on the router.
chrismeister
PostPosted: 10:57 - 17 Dec 2009    Post subject: Reply with quote
Does your router have a DMZ zone on it?
I put my XBOX on the DMZ and left DHCP on for the rest of the network, works fine for me and have open NAT but is kept separate from my network.
T1z3R
PostPosted: 11:08 - 17 Dec 2009    Post subject: Reply with quote
youll only get conflicts if you assign a static IP from within the DHCP range.
duck my sick!
panrider_uk
PostPosted: 11:12 - 17 Dec 2009    Post subject: Reply with quote
job done.
Thumbs Up The way to do it.
Mark
s44678
Guest
PostPosted: 11:27 - 17 Dec 2009    Post subject: Reply with quote
Cheers for the help people.
Will try again with setting the IP outside the range, and if that doesn't work I'll try Chris method using the DMZ.
chrismeister
PostPosted: 12:02 - 17 Dec 2009    Post subject: Reply with quote
The other methods will work as I used that before I discovered I had a preconfigured zone... I just found it easier because its less effort.
The last post was made 16 years, 260 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 57.01 Kb
