| kebabshop |
 kebabshop Derestricted Danger
 Posted: 13:51 - 18 Dec 2009 Post subject: Replacing a brake lever |
Hi chaps(esses).
I had a spill this morning (Snow, round a corner, on my side before I know it) right outside my work. As it was outside of work, I am being picked up by the RAC and taken home tonight (Hopefully)
All that broke was my brake lever, which I find strange as I fell on the clutch lever side
The wife has already been out to pick one up, and I hope it will be an easy replacement.
This is where you guys come in, how difficult is it? The brake lever has come away from what I would call the pinion at the top part of the lever. There is a big flat headed screw beyond that.
Do I take this screw out and put in the new lever, attaching the brake cable to the adjuster, or will I need a new pinion?
Your help would be appreciated
Cheers |
| Itchy |
 Itchy Super Spammer
 Posted: 13:57 - 18 Dec 2009 Post subject: |
Brake cable? even lowly bikes like CGs have hydraulic brakes these days, how old is your bike? , does it have a hydralic cylinder on the bars?.
If it does, it is a simple case of undoing the nut at the bottom and unscrewing the bolt with it pivots off, pulling out the bolt the lever should fall out you replace the lever and bolt and tighten it up..
The only problem you may have with some pattern ones is the brake switch may not work right, my NTV wore a CBR600 lever, I smashed a washer inhalf and glued it to the bit that unpressed the brake light button.
The things to check for are that the bolt which it pivots off is not warped, my NTV one was 0 shaped not O shaped and it was a right burger to fix. Also check the brake light works as well. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| kebabshop |
| The Artist |
 The Artist Super Spammer
 Posted: 14:51 - 18 Dec 2009 Post subject: |
Doubt it will come with the main bit that straps to the bars.
If it just the lever, on hydraulic brakes it is really easy to do though  |
| Shreddie |
 Shreddie Spanner Monkey
The last post was made 16 years, 276 days ago. Instead of replying here, would creating a new thread be more useful? |
