| stirlinggaz |
 Posted: 12:33 - 11 Nov 2009 Post subject: WHAT RELAY? |
hi all,
this question is for those with a better grasp of electrical knowledge than i have. (which wouldnt be hard,lol)
ok, so i have front indicators wich are 21w each.
& iirc, the rear indicators should be either 3.4w or 5w each.(though i have 4 x 5w indicators & 4 x 21w indicators)
what "size" of relay do i need?
the honda one is a silly price, & not having seen one, i dont know what was written on it.
so i figure if i can get a "generic" (ie cheaper) one, i will be sorted, seeing as i have loads of sets of indicators, wiring, & the switch on the bars.
anyone able to offer any advice, on any set up? (either 2 x21w & 2 x5w or 4 x 21w)
im getting fed up with hand signals & now that is dark most of the time, i think it would be safer to have working indicators.
i have tried a couple of random relays,which i had lying around, but the best i could get, was the front indicators only working. (& the rear would either stay on permanately or not work at all, or the relay would make horrendeous clicking noises).
any one able to help?
cheers,
GAZ
edit : i just looked at the wiring diagram & the mtx 200 should be 4 x 21w & the mtx 125 should have 4 x 10w.
so im presuming that simplfies things?
as i only have 21w & 5w indicators, lol |
| finpos |
 finpos World Chat Champion
| Blue_SV650S |
 Posted: 20:14 - 11 Nov 2009 Post subject: |
Are the rear ones that are currently 5w BA9 fitment? https://www.maplin.co.uk/images/full/n81cf_2.jpg
You can get 21w versions of them - that would be your easiest resolve here .... ____________________ The purpose of life is to fight maturity. |
| stirlinggaz |
 Posted: 21:47 - 12 Nov 2009 Post subject: |
hi,
the bike didnt come with any indicators (not a legal requirement on a bike this old) or relay fitted, but it does have the wiring & the switch on the bar.
it should have 4 x 21w indicators, which i have managed to source.
i dont have the original relay.
i also have a couple of random relays(not sure of the wattage, as the markings have rubbed off) & some random pairs of indicators, (most of which are 5w).
the bulbs in the oem indicators can be swapped for 5w bulbs, as i have a pack of duracel l r5w bulbs which fit (there the same fitting as the brake/tail light,only difference is they are not the dual filament type), the others im not sure which type of bulbs are in them...
i tested various combinations of indicators & cant get past the front.
i can get the 2 x 21w front working, but as soon as i connect up the rear, it goes pear shaped.(the indicators either stay on, go off all together &/or the relay starts clicking erratically)
i tried both 21w at front & rear.
2 x21w at front & 2x 5w at rear.
5w at front & rear.
this made me think the relays i have, are either knackered or not powerfull enough to power the 4 x 21w..
am i right in thinking, that to power 4 x 21w bulbs, i need at least a relay of at least 84w??
so whats to stop me using a relay from, say a vauxhall astra? (just an example) as these are around 100w? (& can be had for around a fiver, as compared to the 30 quid david silver wants.
cheers,
GAZ |
| finpos |
| finpos |
| Blue_SV650S |
| stirlinggaz |
| finpos |
| stirlinggaz |
 Posted: 13:46 - 14 Nov 2009 Post subject: |
hi,
thanks.
think i've sussed it.
i was approaching it completely wrong.
i guess i'll get a 2 x 23w (+5w,for the instrument panel) relay.
i'll chuck the relays i have , back in the box of bits.
still cant get over the price of the oem relay, 30 quid , when there are generic ones available for a fiver.
just the wiring to suss out now, lol
cheers,
GAZ |
| stirlinggaz |
| finpos |
| stirlinggaz |
 Posted: 12:11 - 21 Dec 2009 Post subject: |
ah, but my relay only has 2 pins.....
though there are 3 wires down there, but the wiring diagram only shows 2 connected to the relay, the other goes nowhere.
cheers,
GAZ |
| alun111 |
 alun111 World Chat Champion
| Ichy |
 Ichy World Chat Champion
| finpos |
| stirlinggaz |
 Posted: 15:46 - 21 Dec 2009 Post subject: |
goes nowhere.
oem relay is 2 pin.
the one im trying to use at present is 2 pin but different markings.(as the original indicators are 21w!)
bike has 3 wires in that area. (colours dependant on model)
GREY -RELAY
BLACK - RELAY
GREEN - NOWHERE
my easiest solution would be to buy the oem relay & set of oem indicators.
problem is the cost, relay = 30 quid & indicators 40 odd quid.
f*ck that! especially when you can buy relays with the same markings as the oem one for a fiver! & i have a couple of working relays anyway.
i have numerous indicators & numerous bulbs of different wattages.
you will have worked out by now, electrics is not my strong point, lol
cheers,
GAZ |
| Ichy |
The last post was made 16 years, 264 days ago. Instead of replying here, would creating a new thread be more useful? |
