| L3G3ND_MTX |
 L3G3ND_MTX Spanner Monkey
| Alexio |
 Alexio World Chat Champion
| delvey91 |
 delvey91 Crazy Courier
| 10 pence Short |
 10 pence Short Crazy Courier
 Posted: 09:37 - 20 Dec 2009 Post subject: |
How do the gears feel when the engine is off? Could well be the clutch not disengaging enough that makes it hard to select the gears.
If it were the linkage the gear stick would be quite sloppy whether the engine was on or not. look at the gearbox and towards the back there will be rods/linkages,
get someone else to move the gearstick from inside the car whilst watching the linkage move, you should be able to see any wear.
Could also just be adjustment in the clutch cable, usually auto adjusted I think, is the clutch bite very low ie you have to put the clutch pedal all the way to floor to get any gear at all?
If so will be a clutch/cable problem.  ____________________ I haven't had a cont all day, drinkstable. |
| Rejimbo |
 Rejimbo Renault 5 Driver
| Ariel Badger |
 Ariel Badger Super Spammer
| Cigaro |
 Cigaro World Chat Champion
| L3G3ND_MTX |
 Posted: 01:59 - 21 Dec 2009 Post subject: |
Thanks for all the replys, its got worse now, if the engine is running and on i cannot get it into first at all i will litteraly snap the gear lever doing it, if i roll very slowly push as if im going to put it in first then rev the engine (clutch still in) it pops straight into gear no troubles at all.
Ive tryed the cold weather theory and that involves getting slightly thinner or fully synthetic gear oil so it heats up quicker, but then when my car was nice and warm the problem would go away when in fact it just gets worse.
Car doesnt try to move foward if clutch is down, no engine doesnt bog down either so clutch i dont think is at fault.
I'm not just going to take some lads word its the linkage he just jumped in and tryed the gears out and said its most likely the linkage its a common problem on peugeots.
Yes the gears do grind if i don't litteraly ram it in, as i said above ive figured out a nack to get it into gear with the slight revving whilst moving slowly thing, its still killing my elbow (already got bad joints pretty much all over) so need to get it sorted.
I was thinking synchro's or linkage and you guys have helped pretty much confirm it, well if theres any more replys to this post with even more help would be ideal, its going down the garage tomorrow so he will check it out but i will tell him thats what i think it is.
Karma is now being given to all for the help, much appreciated guys!
EDIT: Just to add, the gears feel perfectly fine when the engine is off, the gearstick is'nt 'sloppy' not really sure what you mean by that, alot of play? or moves around in the gear slots?
My thinking if its the clutch not dis-engaging properly then i would have the problem in all of my gears but i only have it in first second and reverse, reverse does'nt just grind a little bit i mean it really fucking grinds and clunks when it goes in, 2 days ago my gears were as smooth as butter, i pulled up in a car park, left the car off for 30 minutes started it up and all of a sudden this problem came up? |
| Phoenix |
 Phoenix Twisted Firestarter
 Posted: 04:53 - 21 Dec 2009 Post subject: |
I'd agree on it being made much worse by the cold weather, my BMW box has got significantly stiffer in the morning until it warms up, the trucks at work are suffering too, allsorts of problems apparently caused by the cold (icing sensors, sticking switches) incredible considering they're designed in Scandinavia
If it's grinding when you put it in reverse, when you go to engage it, declutch in neutral then shift it into 1st and immediately into reverse, should stop it grinding. |
| L3G3ND_MTX |
 Posted: 15:08 - 21 Dec 2009 Post subject: |
Right thanks very much for all that help guys, got it sorted, surprisingly it was'nt any of the problems anyone thaught which im glad because that would of cost alot.
Somehow my clutch cable had managed to un-do itself so my clutch was pretty heavy (was like it when i got it so did'nt think twice) and it started making my gears harder and harder to change, all sorted now and for free, good job my dad knows the guy
Ahhh pain free elbow and silky smooth gear changes are ace!
Again thanks for the help, even though it was'nt the problems said (it could of been by the symptons from the car) karma has been given. |
| Cigaro |
| 10 pence Short |
| L3G3ND_MTX |
 Posted: 00:45 - 22 Dec 2009 Post subject: |
Sorry 10 pence i did'nt see that was kind of scanning through it all to try and get all the info before i went to the garage, my mistake atleast it was'nt something expensive  |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 09:13 - 22 Dec 2009 Post subject: |
you disgust me ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
The last post was made 16 years, 240 days ago. Instead of replying here, would creating a new thread be more useful? |
