1200 Bandit's
vt6
PostPosted: 17:17 - 20 Dec 2009    Post subject: 1200 Bandit's Reply with quote
Alright lads, anyone had experience with these? Things to look out for or needing extra care etc? Should have done the homework before buying but couldn't help myself! The only thing i've noticed so far is the obvious weight of the thing!!
Flip
PostPosted: 17:20 - 20 Dec 2009    Post subject: Reply with quote
I'm sure Keith (kickstart) has one. I'm sure he'll be along to help.
27cows
PostPosted: 17:29 - 20 Dec 2009    Post subject: Reply with quote
I have one...also an impulse buy (£650 - didn't take much persuading Razz ). Cracking bike, if a little portly. Not had to replace anything yet, and nothing has broken. Have only done about 1500 miles on the Bandido, though, so plenty of time for things to do wrong. I know someone who has done 75,000 miles on one with nay bother, so that's reassuring.
ClaireBear
PostPosted: 17:30 - 20 Dec 2009    Post subject: Reply with quote
I ride my other half's bandit 1250 grand touring- its a lovely bike, enjoy every second but its so heavy when trying to park it etc. Smile
mr.kris
PostPosted: 17:43 - 20 Dec 2009    Post subject: Reply with quote
first of all u shud have bought mine but no there mega bikes not meny problems clutches can be a bit week
TS50X---CM125---MZ150---Z250---RS125---ZXR250---BANDIT600---TRX850---TL1000S---CBF600---ZX6R---BANDIT1200S---CG125---VFR800---CBR1000F---CG125---CG125---CB900F---CB900F---CG125---TUONO1000R---KLR600---GSX1300R HAYABUSA---VFR400NC30---BANDIT1200---CG125
HAYABUSA now in use!
PostPosted: 17:46 - 20 Dec 2009    Post subject: Reply with quote
Very different bike to the 1200.
Strong motor, good for big power(10 bhp from an end can IIRC or something stupid), suspension is pretty lame, but it's a muscle bike really so it was never going to be ace.
Usual Suzuki corrosion.
I bet the owner's got Renthals on it and some urban camo trousers/Simpson Bandit helmet tucked away somewhere. Laughing
PostPosted: 17:51 - 20 Dec 2009    Post subject: Reply with quote
I have one. Bought new in 1997.
They are basically reliable. If you want more power then they are one of the few bikes that will give a decent amount extra just from changing the silencer. More power than that is easy to get as you can just stick on GSXR11 bits (although the clutch is up to too much more power).
Finish is not good. Frame on mine was badly corroded underneath, so I had it power coated.
Fuel gauges packing up seems to be a common problem.
Stock exhaust rots where the down pipe joins the link pipe. Almost all the system is stainless except a 2" section there.
Steering head bearings can suffer from previous owners doing wheelies.
Seats split.
Oil coolers cost a fortune from Suzuki if they get damaged.
Rear linkage needs stripping and greasing occasionally.
Above might sound harsh, but mine has been used in most weathers, and the engine isn't standard anymore (the clutch doesn't appreciate 50% more power).
ClaireBear
PostPosted: 18:00 - 20 Dec 2009    Post subject: Reply with quote
Was commenting on the weight statement relating to the 1200 and 1250 Wink
vt6
PostPosted: 18:02 - 20 Dec 2009    Post subject: Reply with quote
BH - You half guessed it lol, renthals, no mirrors, belly pan, braided hoses and after market seat. Never owned this sort of bike before so it'll be interesting
Kickstart - Yep that sections slightly corroded so i'm on the lookout for a full system on ebay. What have you done to yours tuning wise?
PostPosted: 18:10 - 20 Dec 2009    Post subject: Reply with quote
Have a good poke around the bottom of the frame, near where the centre stand mounts, when you do the exhaust.
You can get the section repaired. Think Bandit Mania will do it fairly quickly. Take you old one, stick it in a jig and weld in a replacement section. Cheaper than a full system.
Mine is bored to 1216cc, skimmed and ported head, reprofiled cams, 40mm flat slide carbs and a full Akrapovic system. Also has a Barnett clutch kit, larger oil cooler and some Harris rear sets. Think when set up it was about 157hp, but lost a bit now.
https://www.alfa-pages.co.uk/TempPicture/Bandit1200dsmall.jpg
Keir
PostPosted: 23:22 - 20 Dec 2009    Post subject: Reply with quote
Ive had two, still own one.
first was a black 99 model. had about 25k on the clock and cost me £1600. had a small issue with rust around the rear peg mounts and headstock - a bit of smooth hammerite later and all was fine. also made a strange popping noise on idle and overrun but i never investigated it as i quite liked it. sold for £1850 after 6 months.
then about a month ago i got a 97 maroon model. got 23k on the clock and cost me £1450. very good condition and pretty much standard bar brake lines and exhaust. Fuel gauge didnt work but i found a brand new one on ebay for £10 and its fine now.
Both have been totally reliable and very enjoyable even though they are old and lardy.
https://img.photobucket.com/albums/v383/keir_compact/bandito002.jpg
https://img.photobucket.com/albums/v383/keir_compact/bandit001.jpg
Current : '08 Yamaha FZ1s
Darth
PostPosted: 08:52 - 21 Dec 2009    Post subject: Reply with quote
These are definately on my list of bikes i want to own at some point. These pics are making me want to go an scour ebay!! Black one just above looks very nice Thumbs Up
the grim reaper
PostPosted: 10:02 - 21 Dec 2009    Post subject: Reply with quote
I had the 1200s with full Givi luggage. It was a bit wallowy in the corners but I found that fun and a warning that the limit wasn't far away. I bought mine in 2005 with 5k miles on it, some old boy had owned it and had left the intercom and all associated gubbins on it. I think I paid £2700 and then did 12k miles in about six months. I only sold it as I needed a car to transport my son around. Good bike, although I think there are better bikes out there for similar money.
https://i19.photobucket.com/albums/b176/paul3011/0612gsf121.jpg
Grim
Bishbash
PostPosted: 12:29 - 21 Dec 2009    Post subject: Reply with quote
Bandit 1200's are cracking bikes, so much enjoyment to be had out of them, my mum has one as a spare bike.
Loads of power, but a bit bouncy on the bends and also they are heavy bikes. So don't expect to be flying round corners.
Great straight line bikes and awesome wheelie bikes too Wink
SlimRick
PostPosted: 20:45 - 21 Dec 2009    Post subject: Reply with quote
Mine - 1200cc's of awesome.
https://farm4.static.flickr.com/3244/2914990096_0974832fc7_o.jpg
vt6
PostPosted: 19:57 - 22 Dec 2009    Post subject: Reply with quote
And still no decent weather to have a good blast on it!!
Smooth
PostPosted: 10:54 - 23 Dec 2009    Post subject: Reply with quote
A 1200 is certainly on my wish-list.
I might be able to sneak a silver one in if I make my TDM into a 'naked' and show the missus, then swap it Wink.
I really like the look of that one of Keir_K3's:
TDM850
vt6
PostPosted: 14:00 - 26 Dec 2009    Post subject: Reply with quote
Just a quick update. Managed to get 30 mile in this afternoon just to make sure it's all good and well. Roads fairly slippy but ok to ride. All I can say is F**K ME. Only gave it a little in 2nd and it just took off like something possessed. Just needing a dry day now Very Happy
The last post was made 16 years, 311 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.38 - MySQL Queries: 13 - Page Size: 100.18 Kb
