Starting problem in the cold
alun111
PostPosted: 17:19 - 20 Dec 2009    Post subject: Starting problem in the cold Reply with quote
Hi,
The bike's a 1993 bandit 400 vp (jap import, variable valve)
I've always had problems in the cold starting the bike ever since I've owned it (about 2 and half years now). As I am wanting to retire the bandit to my winter hack I need it to be reliable. I am considering buying a uk model righthand side switchgear (with a light switch on it) so that I can turn the lights off when cranking. This should hopefully give me more power from the battery and for longer.
I have also bought a 9.5ah battery instead of the standard 8ah.
I took a reading of the battery the other morning about 1hr after taking it off charge and it'd dropped to 12.7v (from around 13.2v) just from the cold.
As the battery box is open to the air this doesn't help. I was thinking of wraping the battery or the box in some kind of insulating material.... or buying a better battery box from a tl1000r (or another bike that uses the same battery as the one I have now). Obviously a little modification would be needed though.
What do you think my best option would be? I was also considering lining the original battery box in acrylic sheeting... what do you think?
Am I barking up the wrong tree here?
Thanks
Shreddie
PostPosted: 10:48 - 21 Dec 2009    Post subject: Reply with quote
My bro used to wrap his battery in tin foil (not the connectors though!) for winter... Another option may be some Mylar sheet... It's that aluminised plasic stuff that they wrap hypothermia patients in, you should be able to find some at an outdoor/walking/climbing shop.
Some bikes just don't like starting in cold weather though, my GPZ ws always a PITA.
alun111
PostPosted: 11:58 - 21 Dec 2009    Post subject: Reply with quote
Did your brother have much luck with tin foil?
Obviously anything I wrap the battery in would have to be fire proof.
Cheers for the reply Smile
jokmm
PostPosted: 13:53 - 21 Dec 2009    Post subject: Reply with quote
Wrapping it in something sounds like a good idea to me, winter starting is a bugger!
Shreddie
PostPosted: 15:36 - 21 Dec 2009    Post subject: Reply with quote
Yeah, I think he did other than the fact it corroded and turned to mush pretty quickly (tiny bits or road salt/moisture) which is why I suggested using Mylar instead.
alun111
PostPosted: 18:43 - 21 Dec 2009    Post subject: Reply with quote
Fair enough, I'll have a think about it!
The last post was made 16 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 47.41 Kb
