NS125R werrring noise at front starting from around 6000rpm
richard123456...
PostPosted: 13:23 - 22 Dec 2009    Post subject: NS125R werrring noise at front starting from around 6000rpm Reply with quote
Hi,
I wonder if anyone can help me? I actually have an NS125R not an NSR but I guess this would be the best place to ask my question.
It's been fairly cold where I live recently (in Leeds) and sometimes my bike has started to make this strange high pitched noise after I hit 6000rpm which stays the same until the revs drop to below 2000rpm. It doesn't get less bit by bit, it literally just drops away. I think it sounds electrical as opposed to a scraping or scratching noise. It's similar to the noise that a screen wash pump makes on an old car when its empty...that's probably the best way I can describe it.
If I drive slowly and never put the revs up too high, then I can go a whole journey without hearing it, but if the noise does start it will keep making it until I slow right down or come to a stop. Then it won't start again until I hit the higher revs. It's really weird. Like I say, this has only started happening recently - could it be linked to the cold temperature or is this something to do with a part such as the alternator that needs replacing?
The noise is definitely coming from the front of the bike either under the gauges or under the petrol tank. The bike has a new battery which was purchased in May and was last fully serviced by a garage in September.
Any help anyone can give would be greatly appreciated.
Cheers,
Rich
buddy
PostPosted: 13:35 - 22 Dec 2009    Post subject: Reply with quote
yeah i had a similar thing but it was at like 8000 if i was thrashing it and gradually let the revs drop back past 8000 rpm, just a really high pitched noise, just like what you described
sorry this isnt much help as i havent found out what it is lol and i cant take the revs that high as im running it in as i rebuilt it recently.
When this baby hits 88 miles per hour... you're gonna see some serious shit.
PostPosted: 14:54 - 22 Dec 2009    Post subject: Reply with quote
Is it at all road speed related? Can you trigger it while not moving?
If it is rpm related and behind the clocks then I would suggest checking the rev counter and cable first (may as well check the simple and obvious first). However not much else I can think of that is rpm related in that area.
All the ebst
redline
PostPosted: 21:18 - 23 Dec 2009    Post subject: Reply with quote
I had this type of thing happen on a KMX, In my case the noise was coming from the left engine casing. It turned out to be a part of the (cheap) gasket, which was slightly torn, being flicked by the flywheel when revved above 7,000 revs. I don't know why it did it at 7,000, but not below, unless it was only triggered at that specific velocity.
When the casing and gasket were off the engine, it revved much higher than 7,000 without the sound. Trimmed the gasket and replaced it. The noise stopped.
This might not help you, but it might be something equally random.
The last post was made 16 years, 254 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 41.09 Kb
