My GSF400 Bandit
El.Bandito
PostPosted: 17:59 - 22 Dec 2009    Post subject: My GSF400 Bandit Reply with quote
Hey guys...
First of all im new and glad to be a member of this fantastic website, my problem is i have just recently purchased a bandit, and everytime i start her up, theres an awful rattling sound wen i rev the bike it will power up the same..i have checked the tappets and there fine.. could it possibly be the valves..??
temeluchus
PostPosted: 19:06 - 22 Dec 2009    Post subject: Reply with quote
possibly but I would suspect the camchain tensioner first.
alun111
PostPosted: 20:33 - 22 Dec 2009    Post subject: Reply with quote
Possibly the cam chain tensioner - I had mine go on the bandit 4. Can't remember the exact sympoms as it was a long time ago. You should be able to pick one up for around £15 second hand off ebay.
Frost
PostPosted: 23:58 - 22 Dec 2009    Post subject: Reply with quote
I would suspect the clutch if the sound goes away once you set off.
rob_scott92
PostPosted: 13:56 - 23 Dec 2009    Post subject: Reply with quote
Could possibly be the cam chain itself, i had a similar thing on the gs, the tensioner was at its tightest setting if you like. The chain was just stretched and had to be replaced Sad
How old is it? Could be that the person you bought it off knew it needed doing but couldn't be arsed and didn't tell you Evil or Very Mad . Did you not hear it running when you bought it?
Hope you get it sorted mate Wink
Rob Thumbs Up
SneakyPete
PostPosted: 15:10 - 23 Dec 2009    Post subject: Rattle check.. Reply with quote
..probably been posted before, if you have a rattle and can't tell where from, get a long screwdriver or similar, place against engine and rest handle just behind your ear against your skull - the sound will travel up the screwdriver and will allow you to pinpoint the problem area.
Also seen an old boy balance a pair of carbs using a plastic pipe to listen to the induction sound of each carb!
The last post was made 16 years, 254 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.35 - MySQL Queries: 13 - Page Size: 46.89 Kb
