New chain and sprockets, lacking power in 5th
BlackStallion
PostPosted: 23:11 - 22 Dec 2009    Post subject: New chain and sprockets, lacking power in 5th Reply with quote
Just had a new chain and sprockets fitted today, and i was told the rear sprocket had 1 less tooth compared to my old one.
I've heard going down on sprocket teeth at the rear gives you more top speed, am i right?
Well i'm getting a bit better acceleration, and i hit 66mph in 4th gear today, when i could just hit 60mph with my old sprocket. However, when i change into 5th, the RPM drops, and there's no more power, it's like a useless gear now Rolling Eyes
Pretty gutted, because i used to be able to hit 73mph with my old sprocket. Looks like i won't be hitting 70 anymore Sad
I'm wondering if it's anything to do with the front sprocket, maybe the teeth on that need changing if the teeth are different on the rear Neutral
Any ideas? I'm not sure with the whole sprocket thing...
johnsmith222
PostPosted: 23:24 - 22 Dec 2009    Post subject: Re: New chain and sprockets, lacking power in 5th Reply with quote
There's not really much you can do about this apart from getting a rear sprocket with 1 more tooth.
Less teeth in the rear sprocket means a higher top speed, but the bike needs enough power to actually get it there. It also means slower acceleration (I think you have "better acceleration" because you can use a lower gear to hit higher speeds. eg. before you were using 5th to do 65mph, now you're doing it in 4th. You may have lost a tooth in the rear, but the differences in ratios between 4th and 5th gear makes up for the missing tooth and some more).
Apparently losing 1 tooth on the front is like gaining 3 teeth in the rear. I would replace the rear sprocket for +1 tooth (back to the same as was on before) if I were you rather than losing a tooth on the front as you'd probably get a lower top speed than 66mph, but would be able to use 5th gear. The bike would feel like it pulled more but it sounds like top speed is important to you.
I'd just get a rear sprocket with 1 more tooth on there.
BlackStallion
PostPosted: 23:37 - 22 Dec 2009    Post subject: Reply with quote
Yeah, i guess going back to my previous sprocket would give me my top speed back Thumbs Up
I just can't afford a new one right now, would be a waste of money really. I had no idea it was going to be 1 tooth less though. When i flicked into 5th, i was really looking forward for that extra little boost, but there was nothing there, and even with the throttle wide open, my speed was either staying the same, or dropping by 5mph sometimes, which i think is strange... Rolling Eyes
With being a 4 stroke, you need to ride for a good half an hour until the engine's warmed up fully, so it may just be the cold weather, because in the summer (my 125 much prefers warmer weather) after riding for a while, i could get a decent top speed out if my bike, compared to earlier the same day.
Just a guess... Rolling Eyes
I'll have to see when the weather becomes more "comfortably ridable" Thumbs Up
P.
PostPosted: 23:58 - 22 Dec 2009    Post subject: Reply with quote
With my hyosung, not sure if thats the bike you are using, but anyway..
I used to let mine sit there and idle for like 2-3 mins.. then ride real careful... Always helped me and the bike was just kinda really crap for the whole journey if it wasnt warm!
That thing hit stupid speeds for a heavy v twin 125.
I found when i changed my chain and sprockets after they kinda "bed in" it was alot better... took about 100-150 miles, was adjusting quite a bit in that time.
But after that it felt back to normal.
BlackStallion
PostPosted: 00:06 - 23 Dec 2009    Post subject: Reply with quote
Read your sig mate, you had the Comet, which is a nice bike Thumbs Up
I was told that i needed to give the chain and sprockets a chance to bed in, because the chain stretches rapidly, and needs to be adjusted every so often. I think you're right though, because i got straight on my bike after everything was fitted, and rode 70 miles back home, plus it was freezing!
The mechanic told me i'd get atleast a few extra mph out of the rear sprocket, but i guess i could ride in 4th from now on, it's a nice gear to ride in, and i've got to admit, for once tooth's difference, you can feel the improvement in acceleration, which i think is where i'm getting the advantage, but with the loss of top speed. Atleast i can overtake quicker now Wink
I'll just have to see padwax mate, cheers Thumbs Up
BlackStallion
PostPosted: 00:07 - 23 Dec 2009    Post subject: Reply with quote
This is the rear sprocket i've got
https://www.startright.co.uk/index.php?main_page=product_info&cPath=145_156&products_id=13902
Like it says, squeeze that extra few miles an hour Thumbs Up
P.
PostPosted: 00:18 - 23 Dec 2009    Post subject: Reply with quote
yea i got all my bits from there Thumbs Up
Comet was fantastic...wasnt learner legal though...bastard bike shop Razz
Still, sounded nice, went fast enough for me to use motorways, great MPG, HUGE thing, big tyres, definitely made me a better rider, or atleast did the step to a bigger size bike before getting a much bigger cc.
Try bedding the chain and sprockets, letting it warm up substantially, should keep you going for a while!
Definitely watch the chain slack etc, that made a bit of difference to me...kept it relatively tight, about an inch movement.
johnsmith222
PostPosted: 00:37 - 23 Dec 2009    Post subject: Reply with quote
Losing a tooth in the rear sprocket should mean an increased top speed but less acceleration. The reason why you have experienced a drop in top speed is because your bike does not have enough power to actually pull through 5th gear with 1 tooth less. Because you are now doing 60ish mph in 4th gear instead of 5th gear is the reason why you are feeling it has better acceleration. Although you have actually decreased acceleration in terms of comparing each gear with the same gear minus 1 tooth then you have lost acceleration. EG. compare 4th to 4th, 5th to 5th before and after the -1 tooth.
If you want more acceleration then increase the number of teeth on the rear, don't reduce the number.
You are comparing the acceleration in 5th gear before, to the acceleration in 4th after. That is why it seems to accelerate quicker.
I'd take whatever sprocket is on there just now and plus 2 teeth if I were you.
BlackStallion
PostPosted: 00:49 - 23 Dec 2009    Post subject: Reply with quote
I think you've hit the nail on the head dave Rolling Eyes
Basically, i've lost out, i haven't gained anything, i haven't actually got better acceleration, just feels it (pointless) and with being a 125 4 stroke engine, i can see what you mean about not having enough power in 5th. So i guess i've lost out on top speed too...
I'm going to do what padwax said, and give it some time to bed in, adjust the chain when it starts to stretch, and just see if there's any difference over the next few days.
I haven't got the money to go back to a standard sprocket, i'll just have to make do with what i've got. Pity really Sad
johnsmith222
PostPosted: 01:32 - 23 Dec 2009    Post subject: Reply with quote
Single sprockets are quite cheap tbh. If fitting it is an issue then I'm sure someone on here nearby would be willing to give you a hand swapping the sprocket. It'll be easier to fit if you wait a bit for the chain to stretch. That way the chain may not need to be split to change the sprocket.
What I mean is that the bike doesn't have enough power to pull through 5th gear when you lose a tooth on the rear sprocket. The problem is the number of teeth on the rear sprocket, not the power that the bike puts out.
It was not a dig at whatever power your bike puts out. (I'm not saying you think it was, I just think it looked that way after re reading.)
PostPosted: 07:48 - 23 Dec 2009    Post subject: Reply with quote
You're only going to get more top-speed if you're already revving-out in top gear generally - even some cases then you won't if the gearing is already 'perfect'.
PostPosted: 08:02 - 23 Dec 2009    Post subject: Reply with quote
Where's your speedo driven from, gearbox or front wheel? If it's gearbox one then changing the final drive gearing will mean your speedo is inaccurate.
Smaller sprocket at the back will give you worse acceleration and higher top speed if the bike has got the power to do so which it sounds like yours doesn't.
In plenty of cases down gearing a bike (which gives more acceleration) will also mean a faster top speed as the engine is then able to be go right to the red line in top gear.
Vin
PostPosted: 08:07 - 23 Dec 2009    Post subject: Reply with quote
Go on a diet, find a big long downhill, get flat on the tank you'll easily do a ton. Thumbs Up Laughing
BlackStallion
PostPosted: 08:33 - 23 Dec 2009    Post subject: Reply with quote
Rolling Eyes
Don't be stupid mate, i know you're not making a dig at me, you just explained it well, and after re-reading what i put, it does sound slightly defensive, as if you've, well "made a dig at me".
Vincent offered to help me out last week, he lives in Cambridge, and i live in Peterborough, so it wouldn't be to far to travel if he was free to help me out Thumbs Up
I'm skint at the moment, blew crazy amounts of money on bike gear this last month or so, and got more christmas presents than i've ever bought anyone in my whole lifetime Laughing
I'll just have to put up with the 46 tooth sprocket, and see if i can get one for the new year.
I know what you're saying about my bike hitting above 60 in 4th, which is what it used to in 5th, but the fact i could hit 73 in 5th before this sprocket, i'm sure my bike has the power to atleast pull through and hit 70, maybe it can, but in 4th. After all, i didn't blast it down the road last night, to icy, so once all this shit weather clears up, maybe i'll see a difference Thumbs Up
Yeah, my speedo uses the gearbox to measure my speed, and if you say my speedo is inaccurate, does that mean i could be hitting 70, but due to my speedometers reading, it appears i'm doing 66mph, or have i got it wrong, and in fact, i'm going even slower than my speedo's reading?
I'm skinny enough as it is mate Laughing but i'm sure i'd hit good speeds in 5th Thumbs Up wish it was a ton... Rolling Eyes i'll just have to wait until i past my test and get myself a Bandit, then i'll be able to hit speeds like that, comfortably for a change Very Happy
PostPosted: 08:52 - 23 Dec 2009    Post subject: Reply with quote
With a smaller rear sprocket the speedo will be under reading, as it's only 1 tooth smaller than standard then it'll only be out by a small amount. But as the speedo will over read as standard, it might now be closer to being right.
It's possible to work out from the gear ratios what the speedo inaccuracy is and you can get little electric gadgets that correct your speedo, but it's more hassle than it's worth when your speedo is only out by a small amount cos you've already got a pretty good idea how fast you're going.
BlackStallion
PostPosted: 09:15 - 23 Dec 2009    Post subject: Reply with quote
Well, when my speedo read 73mph, i have to drop about 3mph for an accurate reading, so that's 70mph.
So if my speedo is saying 66mph in 4th, i'm really doing 63mph, even with the low power my engine delivers, i really thought it would still even say 70mph (really 67) but i'm still happy with the bike, and when i come to sell it, atleast it will have a relatively new chain and sprocket kit with hundreds/thousands of miles left in them Thumbs Up
Kwaks
I'm not a fast rider
PostPosted: 09:26 - 23 Dec 2009    Post subject: Reply with quote
The "feel" of extra acceleration might just be the new chain being better adjusted and having less stretch applied.
Or as usual in my case its all in your head Laughing
www.cliqueycuntsmcc.co.uk
PostPosted: 09:27 - 23 Dec 2009    Post subject: Reply with quote
Can you hit the redline in top gear? if you can drop a tooth on the rear, if you can't add some. This will get you more accelaration and a highier speed. My old GS wouldn't rev out so I dropped a tooth on the front (Same as adding to the rear) and the top speed went up by 10mph.
PostPosted: 09:34 - 23 Dec 2009    Post subject: Reply with quote
While all the above is true, it sounds a bit strange for only changing the rear sprocket by 1 tooth. Going from 46 to 45 teeth is a tiny change. Even if you pulled the same revs in top the difference in speed would be under 1.5mph. I would doubt it is enough to knock ~10mph from your top speed.
If you could hit 60mph before in 4th then you should be hitting 61.3 now at the same revs. But as your speedo is driven off the gearbox it will still show exactly the same speed as before even if you are going a tad faster.
What size front sprocket is on there?
BlackStallion
PostPosted: 13:52 - 23 Dec 2009    Post subject: Reply with quote
My front sprocket is 15T and my rear sprocket is 46T, it used to be 47, which was the standard sprocket.
That's exactly what i mean though, it does seem strange, with 1 tooth down on the rear sprocket, and such a dramatic change in speed, for a 125 anyway. 5th gear just feels like a cruising gear, and even with the throttle wide open, the speed stays the same or maybe even drops, it doesn't increase. I know i don't have a lot of power, but i would of thought changing from 4th to 5th would have been different, i thought 5th would still get 70mph, even if it took a year to get there, but it just doesn't want to go any faster.
The last post was made 16 years, 26 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 116.16 Kb
