Say hyperthetically...
PostPosted: 11:19 - 24 Dec 2009    Post subject: Say hyperthetically... Reply with quote
...somebody put a good few tanks of unleaded though a bike that was supposed to take leaded fuel and now it will not start.
What sort of damage could have been done?
PostPosted: 11:31 - 24 Dec 2009    Post subject: Reply with quote
Possibly valve seat recession, and left long enough the clearances will likely tighten up and it will burn out a valve.
First thing to try is to adjust the valve clearances.
What hypothetical engine?
PostPosted: 11:45 - 24 Dec 2009    Post subject: Reply with quote
A late 60's triumph 650 twin, It's not me by the way it my dad, Laughing
PostPosted: 11:50 - 24 Dec 2009    Post subject: Reply with quote
Should be easy enough to whip the head off and check. If needs be get the seats replaced with harder ones.
PostPosted: 17:01 - 24 Dec 2009    Post subject: Reply with quote
Usually it takes several hundred miles to remove the protective TET coating built up from using leaded petrol and then a lot more miles on top of that to cause damage valve seat damage through using unleaded petrol. But it's also dependant on the quality of the valve seats to start with.
Might be worth a few squirts of oil down each plug hole to seal the rings, then turn the engine over and check for (audible) compression loss via the exhausts.
If there is still clearance betwen the rockers and valve tip and compression is good, might be worthwhilst checking the basics first before opening up the top end, even though it's just a few hours work on one of those engines.
Ariel Badger
PostPosted: 17:17 - 24 Dec 2009    Post subject: Reply with quote
I myself have done 10s of thousands of miles on bikes that should have had lead in the fuel to no ill effect. I doubt it is unleaded that killed your dad's bike.
PostPosted: 19:33 - 24 Dec 2009    Post subject: Reply with quote
It probably has done about 500 miles or so, we really need to check it out but TBH it is far too cold Laughing
tatters
Exxon Valdez
PostPosted: 19:49 - 24 Dec 2009    Post subject: Reply with quote
Bikes with alumium cylinder heads generally have hardened valve seats so are fine with unleaded fuel.
though l know people with pre unit singles with cast iron heads who have run unleaded fuel for over 20 years with no problems.
PostPosted: 10:47 - 25 Dec 2009    Post subject: Reply with quote
Would say that is nowhere near enough to cause major issues.
prawny1
PostPosted: 22:02 - 27 Dec 2009    Post subject: Reply with quote
The ignition timing being set to still run leaded could do more damage in the short term than the actual lack of lead on the valve seat.
The different burn characteristics would likely need a minor plug heat range change too.
The last post was made 16 years, 255 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 66.67 Kb
