Jubilee clip tolerances
Trylski
PostPosted: 22:38 - 25 Dec 2009    Post subject: Jubilee clip tolerances Reply with quote
Anyone got any idea roughly what temperature jubilee clips melt at (assuming a standard one off the shelf at halfords or simmilar)
Second, how hot does it get inside the valve cover where all the tappets are.
Cheers.
Ps have done some googling with little success
Current Bike: Suzuki Bandit N600 '99,
- CBT: Passed 02/2008 - Theory : Passed 24/02/09 Test: Passed 09/03/09 - 2011 33bhp over
Pie-Roe
PostPosted: 23:37 - 25 Dec 2009    Post subject: Reply with quote
I don't know the answer, but I don't ever want to buy a bike off you Very Happy
Pyro
Ichy
PostPosted: 00:12 - 26 Dec 2009    Post subject: Reply with quote
1300c - 1400c according to the tye of steel they are made out of.
MattHirst
PostPosted: 12:07 - 26 Dec 2009    Post subject: Reply with quote
I'm assuming they will be made out of a mild steel, generally galvanised with zinc. So Ichy's 1300-1400c will be round about right.
Although they will start to deform at only a few hundred deg, along with changes to their molecular structure.
As for how hot it will get, i can't imagine it will get any hotter than the cylinder block, probably considerabley cooler. I'm guessing at maybe around 50-60 deg where as the rest of your engine (ie cyl block) will probably get to around 80.
May we ask why? Laughing
Phoenix
Twisted Firestarter
PostPosted: 13:22 - 26 Dec 2009    Post subject: Reply with quote
His camchain broke so he's going to make a daisy chain of jubilee clips. Inside the valve cover doesn't get that hot, the oil doesn't burn so a steel clip isn't going to.
Trylski
PostPosted: 15:26 - 26 Dec 2009    Post subject: Reply with quote
Not the cam chain :/
One of the cam journals split so the valve cover doesn't bolt down tightly enough and I'm losing oil so my theory is that it will hold the split thread closed so the bolt can get into it and hold it tight enough.
Will have to do until I can get hold of a new head/get the journals repaired.
Ichy
PostPosted: 17:35 - 26 Dec 2009    Post subject: Reply with quote
The valve cover will have no effect on compression.
Trylski
PostPosted: 18:17 - 26 Dec 2009    Post subject: Reply with quote
Shocked By compression I mean oil Laughing
Ichy
PostPosted: 22:03 - 26 Dec 2009    Post subject: Reply with quote
So you have an oil leak?
Just to keep the pedants happy, understand that this answer has risks.
How about putting some liquid gasket around the mating face before fitting the valve cover? Does the journal have any room to fit a longer bolt?
ZRX61
Victor Meldrew
PostPosted: 00:50 - 28 Dec 2009    Post subject: Reply with quote
You can't compress oil, try again. Rolling Eyes
MattHirst
PostPosted: 12:03 - 28 Dec 2009    Post subject: Reply with quote
Well you can, but it goes boom when compressed Razz
Trylski
PostPosted: 16:40 - 28 Dec 2009    Post subject: Reply with quote
If you read it the post again and replace the word compression with oil it makes sense. Nowhere does it say I'm compressing oil.
The last post was made 16 years, 228 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.27 Sec - Server Load: 1.47 - MySQL Queries: 13 - Page Size: 72.89 Kb
