Honda Magna won't start
Dan79
PostPosted: 15:44 - 26 Dec 2009    Post subject: Honda Magna won't start Reply with quote
I tried to start my Honda Magna V30 500cc today after two months tucked away in the shed, simply for a check over. After reconnecting the battery and attempting to start as per usual, it tried to turn over once, and thereafter the solenoid would simply make clicking noises. It would then fail to do anything whatsoever until left alone for a few minutes, then it would click again for a few attempts but still not turn the engine over at all.
The horn and lights would all work, at least prior to pressing the starter button. These would all then weaken after a few attempts, before becoming strong again once left for a while.
The battery is measuring about 11.9 volts and has been kept dry and in the house separate from the bike since hibernation.
The manual does give a procedure for checking the continuity of the solenoid, but this involves connecting it to a 12V battery during the check which seems like a recipe for an electric shock - I don't claim to be any sort of expert on electricals !
Any ideas for diagnosing this fault most welcome. Thank you
PostPosted: 16:10 - 26 Dec 2009    Post subject: Reply with quote
Charge the battery up.
Fisty
PostPosted: 16:11 - 26 Dec 2009    Post subject: Reply with quote
Battery is too weak to start it. Try jump starting it.
Fatter and faster than Fret
Cigaro
PostPosted: 18:07 - 26 Dec 2009    Post subject: Reply with quote
As others have said, simply a flat battery.
You know they lose charge over time right?
Dan79
PostPosted: 22:10 - 26 Dec 2009    Post subject: Reply with quote
I'll give that a try.
I do know they lose charge, but like I mentioned Im not an expert in things electrical, didn't realise a loss of about 0.1v would affect to that extent. My other bike's a six volt kick-start which seems to tolerate much greater losses in voltage - I don't always realise the difference between 6v and 12v !
Any suggestions for preserving battery voltage whilst kept in a cardboard box in a dry loft more than welcome
Thank you
PostPosted: 00:01 - 27 Dec 2009    Post subject: Reply with quote
Thank you
The reason the kickstart 6v bike tolerates more is because all you're running off the battery is lights. A starter motor needs quite a lot of power to turn the engine over.
And a battery should be at around 13v. At 11.9v it's very low.
WishayKillie
PostPosted: 01:25 - 27 Dec 2009    Post subject: Reply with quote
Thank you
It's roughly 6v Wink Thumbs Up
As everybody else has said charge it up, although it might be to far gone by the voltage reading.
Get yourself a trickle charger or an Optimate to keep your battery in good condition Thumbs Up
Dan79
PostPosted: 20:37 - 30 Dec 2009    Post subject: Reply with quote
Thanks for all the helpful replies, I have an Accumate charger on order which will hopefully keep things going in the future !
Dan79
PostPosted: 20:49 - 01 Jan 2010    Post subject: Reply with quote
Just an update - battery fully charged and engine ran today so hopefully should not happen again. Thanks to all who offered advice
The last post was made 16 years, 279 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 59.81 Kb
