Yamaha XJ400 electric problem
jp14
PostPosted: 18:02 - 28 Dec 2009    Post subject: Yamaha XJ400 electric problem Reply with quote
I had problems with my XJ not starting, I had to keep bump starting it and this guy from the AA (off duty) helped me bump start it.
He told me he thought it was the regulator because I'd only just got a new battery.
I bought a new (secondhand) regulator and it was a different model, so I was hesitant to use it but I tried it and as the battery was completely dead I used my dad's battery to jump it. It was running oddly and the battery was not charging itself, I left it running for about 10 mins. The lights were flickering when I revved it and when I turned it off the battery went completely dead again.
Has anyone got any ideas to what it could be?
TUG
PostPosted: 18:32 - 28 Dec 2009    Post subject: Reply with quote
How recent is the battery, and when it went flat did you put on charge asap or leave it.
Sounds like you need to put an altimeter on the battery and take some readings, if it is the charging system it could need a new stator or the wires leading to it checking for breaks and repairing.
All this is on a Could be basis, without seeing the bike its hard to say.
Haz ER-5, innit!
jp14
PostPosted: 18:57 - 28 Dec 2009    Post subject: Reply with quote
The battery's weeks old and I don't have a charger so I'm probably going to need to borrow one of my mates; I wasn't sure whether running it would be enough to charge it.
Thanks
TUG
PostPosted: 22:10 - 28 Dec 2009    Post subject: Reply with quote
With all the lights flickering i would think theres something seriously wrong, get yourself a multimeter and measure up the feeds from the battery, should read 13v at idle and then something like 15v at 4-5k? Cant remember the exacts those are with the lights on btw.
Haz ER-5, innit!
serlant
PostPosted: 08:32 - 29 Dec 2009    Post subject: Reply with quote
If you get a haynes manual it will say the exact values in the haynes manual for my 1990 xj600 it is
charging voltage 14 to 15 volts.
nominal output 14 volts, 21 amps at 5000rpm.
non load regulated voltage 14.3 to 15.3 volts
Stalk
PostPosted: 21:31 - 29 Dec 2009    Post subject: Reply with quote
An alternator will not charge a dead battery, needs something to excite the field windings in the aternator to produce a charge. Maybe charge the battery off the bike and try again?
Hope it helps
Stalk
Raffles
PostPosted: 21:55 - 29 Dec 2009    Post subject: Reply with quote
Oh yes it will. Once jump started the alternator will produce full power if it is in sound condition.
jp14
PostPosted: 12:19 - 30 Dec 2009    Post subject: Reply with quote
I charged my battery but there wasn't enough power to start it still, I tried my old rectifier and it still didn't start, I haven't had a chance to jump lead it yet.
Thanks for your suggestions
TUG
PostPosted: 15:12 - 30 Dec 2009    Post subject: Reply with quote
I think you killed your battery by running it flat and letting it discharge. Jump it, a car battery is fine just dont jump it from a started car. If the bike starts but then dies after the starter cables are removed you have yourself a dead battery. If not get some reading via multimeter and let us know of the results. Thumbs Up
Haz ER-5, innit!
jp14
PostPosted: 15:57 - 30 Dec 2009    Post subject: Reply with quote
XlonewolfX wrote:
Jump it, a car battery is fine just dont jump it from a started car.If not get some reading via multimeter and let us know of the results. Thumbs Up
Confused The bike still runs without the cables and no, the car wasn't running.
I'll try and get hold of a multimeter.
PostPosted: 19:45 - 30 Dec 2009    Post subject: Reply with quote
possibly one of the fuses? My GS refused to charge the battery.
Brand new one, the bloody thing just kept clicking.
Could even be starter motor...that was the 2nd fault with my bike Sad
What my dad did was take the starter motors earth and put the ground wire directly on the negative battery terminal, started everytime since!!
jp14
PostPosted: 11:20 - 31 Dec 2009    Post subject: Reply with quote
Yeah, I thought about it being the fuses, but I haven't got the knowledge to tell (even though it's probably quite simple to work out), I'll look into that one though.
I jump started it and then a few times after it started on the button, but then stopped- this was with the new regulator in, I'm thinking it might be the flywheel magneto thing.
TUG
PostPosted: 16:53 - 31 Dec 2009    Post subject: Reply with quote
Ok this still doesnt rule out a duff battery though i'm affraid. I had a problem like this on my FZR 400, it would hold a charge then full discharge within a minute.
Get hold of a multimeter and then we can sort this out.
Haz ER-5, innit!
jp14
PostPosted: 18:25 - 06 Jan 2010    Post subject: Reply with quote
Ok, I got the multimeter and tested the battery, it says around the 12-12.5 mark not running and running at 3-4000 revs, I tested the plug that goes into the rectifier (for resistance in ohms) and that all appears to be correct, I also tested the rectifiers for resistance and on the old one there was resistance but on the new one there wasn't any resistance (I'm not sure what this means). I then put the old rectifier back on, but the bike wouldn't start by its own power so I jump(lead)ed it then turned it off and tried the button, it worked a few times but getting weaker and weaker until it didn't start.
I would try the stator but I don't know how to get to it or where it is (or what it looks like Embarassed).
Any ideas?
TUG
PostPosted: 18:53 - 06 Jan 2010    Post subject: Reply with quote
It should be on the left hand side IIRC, the casing is quite round and bulbus.
Theres a nice black coated set of wires going upwards aswell, unfortunaly i have never tested one so i'm no use to you at this stage.
Haz ER-5, innit!
serlant
PostPosted: 11:06 - 07 Jan 2010    Post subject: Reply with quote
if the battery voltage is the same not running, as it is when its at say 5k revs, then its not charging, should go up to 13-14v at about 5k rpms.
The last post was made 16 years, 264 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.18 - MySQL Queries: 13 - Page Size: 88.3 Kb
