Change oil on Honda XLR 125R
 Topic moved: from General Bike Chat to The Workshop by Bendy (26 Jun 2004 - 10:27)
wisebeuy
PostPosted: 22:07 - 25 Jun 2004    Post subject: Change oil on Honda XLR 125R Reply with quote
You're not going to believe this, but I can't find the bolt/plug to drain the oil from the engine. The only possible culprit I can see is a 1" bolt near the bottom of the engine, but I would like some conformation first, as it wasn't a cheap bike. So if anyone has any advice, or better yet, a picture, then please let me know.
Many thanks
Andrew
Phoenix
Twisted Firestarter
PostPosted: 03:21 - 26 Jun 2004    Post subject: Reply with quote
Make sure it's the right bolt, there's 2 on the bottom of the engine, one lets all the oil out, remove the other one and the engine falls out! Shifty
Frost
PostPosted: 04:23 - 26 Jun 2004    Post subject: Reply with quote
look at the bolt, if it appears to be as low as you could possibly get a bolt and that it has some form of washer/seal then that is the sump plug
coolfox1
PostPosted: 18:33 - 28 Jun 2004    Post subject: Reply with quote
ye lowest bolt you can find, mine is on the oposite side to the gear change and slight bit further forward
Guest
PostPosted: 18:49 - 28 Jun 2004    Post subject: Reply with quote
Couldn't find the XL125 on Bikebandit.com, bit this is from an XR100R (US market)
The drain plug is number 12
The last post was made 21 years, 178 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.63 - MySQL Queries: 16 - Page Size: 42.92 Kb
