Braided line - HEL/Venhill, and do they really last forever?
neil.
PostPosted: 18:31 - 29 Dec 2009    Post subject: Braided line - HEL/Venhill, and do they really last forever? Reply with quote
Hey folks,
Thinking about going with a braided line for the YBR as they apparently last forever (is this actually true?), and the current OEM rubber hose is due for replacement. I've found a couple of different ones - one from HEL and the other from Venhill:
https://cgi.ebay.co.uk/VENHILL-Brake-line-hose-kit-YAMAHA-YBR125-06-07-FRONT_W0QQitemZ200416488405QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item2ea9c0ebd5
https://cgi.ebay.co.uk/HEL-Brake-Lines-Yamaha-YBR125-2006-2009_W0QQitemZ110472595159QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item19b8ae06d7#ht_2897wt_941
Has anyone had experience of either brand, or could anyone advise on which may be superior?
Cheers! Thumbs Up
PostPosted: 18:39 - 29 Dec 2009    Post subject: Reply with quote
Personally I would say that rubber hoses are not that short lived (my 1991 FZR600 has the original rubber hoses on it).
Not that much in braided hoses to degrade with age, but they do get easily damaged by rubbing on things (and also easily damage what they rub on). This is the result of a ~1 year old braided hose that was rubbing:-
https://www.alfa-pages.co.uk/TempPicture/colsbrake.jpg
Don't really think there is much to chose from between the products of the different suppliers. Just do not buy any with alloy fittings (don't think either Venhill or HEL sell any with alloy fittings).
neil.
PostPosted: 18:44 - 29 Dec 2009    Post subject: Reply with quote
Hi Keith,
Thankyou for the info. It seems the Venhill lines are PVC coated so I'd assume rubbing isn't an issue there, especially if things are routed carefully? Fittings are steel and washers are copper from the looks of things. Tempting... Very Happy
Edit: The HEL lines are also PVC coated.
PostPosted: 18:53 - 29 Dec 2009    Post subject: Reply with quote
The shrink wrap coating does make the rubbing less of a problem, but they still need to be routed carefully (the covering will wear through fairly easily). The HEL lines look like they have a shrink wrap coating as well.
Stainless steel fittings are probably the most long lived (and most expensive). You can also get them with a cadmium plated finish (lasts well, but expect some cosmetic corrosion at some point) or a chrome finish (seems more easily damaged when you fit the hoses).
However unless your current line is knackered I would say it is mainly a cosmetic change.
neil.
PostPosted: 18:59 - 29 Dec 2009    Post subject: Reply with quote
I'm just going by the service schedule that says every 4 years for OEM brake line replacement. Current one looks okay though (can't see cracking), but I'm just worried about how it'll behave as it ages.
PostPosted: 19:12 - 29 Dec 2009    Post subject: Reply with quote
I would suspect that if the braided hose suppliers were as paranoid as the bike makers they would also specify a similar replacement schedule.
While rubber hoses do degrade eventually, I don't think it is anything like as big an issue as some think.
PostPosted: 14:55 - 30 Dec 2009    Post subject: Reply with quote
Vincent wrote:
One problem I've had with old rubber only hoses is that when you apply the brake, the hose will stretch like a baloon causing your brakes to feel spongy.
While back I measured how much the hoses balooned on a few of our bikes when you pulled the brakes hard. OK, this is measuring the external diameter but the ones that expanded the most were the standard fit braided hoses on Charlottes Triumph Thunderbird. Certainly more than any of the rubber hoses.
Dan79
PostPosted: 22:02 - 01 Jan 2010    Post subject: Reply with quote
I would agree with some of the other posters who say rubber hoses will last more than the recommended renewal intervals. My old bike, a 1984 Honda VF500, still had what appeared to be its original rubber brake and clutch hoses when I sold it in 2005 with about 40,000m+ on it and one of my two current bikes, also a 1984 Honda VF500 with just over 50,000m, still has its original rubber front brake hose (I replaced the clutch line with a braided one last summer as the outer casing of a section of the old rubber one had started to split at a chafing point - before it had any effect on operation).
The last post was made 16 years, 279 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 65.85 Kb
