| RXZMATT |
 RXZMATT Derestricted Danger
| Dan79 |
 Dan79 Scooby Slapper
| 27cows |
 27cows World Chat Champion
| RXZMATT |
| Serendipity |
 Serendipity World Chat Champion
| 27cows |
 Posted: 11:44 - 31 Dec 2009 Post subject: |
On the plus side, RXS headlight bulbs last more or less forever if you don't physically break them. I've only ever had one blow in 19 years...but I have busted a couple accidentally.
Rears are a different matter. You can have one last two or three years, then have three blow in a week. Bizarre carry on  |
| RXZMATT |
 Posted: 16:31 - 31 Dec 2009 Post subject: |
SERIOUSLY PISSED OFF NOW. I managed to get the bulb I've been looking for, for DAYS. Fitted it just in time for the mot AND THE BULB BLEW. Someone really must not like me. What would cause this? I guess I'm staying in tonight. ____________________ Matthew |
| 27cows |
| RXZMATT |
| 27cows |
 Posted: 16:54 - 31 Dec 2009 Post subject: |
Replace it I must say that in all my years of owning an RXS (which has a very similar electrical system) I've never had a regulator or rectifier fail. The RS100 has points, I think, so the alternator set up will be different to the RX. Whether or not the charging system is the same, I really don't know.
Did the bulb blow when you were riding the bike? |
| RXZMATT |
| 27cows |
| RXZMATT |
| 27cows |
| Raffles |
 Raffles World Chat Champion
| 27cows |
| RXZMATT |
| RXZMATT |
| 27cows |
 Posted: 18:06 - 01 Jan 2010 Post subject: |
There are numerous earth wires (black on the RXS, presumably the same on the RS), but only two main points of contact. You need to check the (probably) blue wire from the battery is undamaged making good contact with its point on the frame. There may well be rust under the point where the connector is touching the frame.
You also need to pay particular attention to the (probably) black earth wire which should be located near or directly under the rectifier (under the tank, towards the front of the bike).
Give all of the wiring a close visual inspection and keep an eye open for any damage, trapped wires and loose/corroded connections.
On the RXS, the regulator is under the tank, near the centre of the bike. It's connected by a single yellow/white wire - pay close attention to that. Of course, if the regulator has failed, there will probably be no obvious sign, but like I said above, I've never had one pack up on me in nearly 20 years of hard use. |
| RXZMATT |
 Posted: 21:57 - 01 Jan 2010 Post subject: |
Okay, well I will get on it first thing tomorrow morning. I will let you know how I get on Thanks very much again  ____________________ Matthew |
| RXZMATT |
| 27cows |
 Posted: 13:02 - 02 Jan 2010 Post subject: |
The indicators flash too fast when the relay is on the blink (no pun etc ) or when the relay and indicator bulbs aren't compatible (ie, if a 23W relay is used with 10W bulbs, for instance). If the indicators flash faster as the revs rise, the chances are the regulator is the cause of your problems. |
| RXZMATT |
 Posted: 13:19 - 02 Jan 2010 Post subject: |
They dont flash faster they flash brighter with revs. Where would I find the relay? How do I check if its not the right relay? Thanks again  ____________________ Matthew |
| RXZMATT |
| 27cows |
The last post was made 16 years, 303 days ago. Instead of replying here, would creating a new thread be more useful? |
