Will Sm wheels off a dt 125x 2006 fit a dtr?
Jamie S
PostPosted: 01:30 - 01 Jan 2010    Post subject: Will Sm wheels off a dt 125x 2006 fit a dtr? Reply with quote
Hey guys, been offerd an amazing deal, Front and rear wheels for a dt125x 2006 + brembo brakes for just £150!
My question is, will the wheels fit ? or will diffirent spacers be needed?
Jamie S
PostPosted: 01:47 - 01 Jan 2010    Post subject: Reply with quote
If not would I be able to buy a seccond set of dtr hubs and lace the rims on to them ?
PostPosted: 02:12 - 01 Jan 2010    Post subject: Re: Will Sm wheels off a dt 125x 2006 fit a dtr? Reply with quote
You will need to make up some spacers for the front wheel (i got some steel tubing the same diameter as the original spacer and just cut it to size) but the rear wheel will slot straight in.
Front caliper is another problem.The brembo won't fit because the SM wheels have bigger disks so the caliper bracket on the forks won't be high enough.
I would advise you to buy some dtx forks aswell which would make it all a straight fit.
You could make/have made a bracket to make the brembo fit the dtr forks but it's more trouble and expense than it's worth.You can get dtx forks for under £50.
HTH
Dave
DRZ-400sm
Jamie S
PostPosted: 02:30 - 01 Jan 2010    Post subject: Reply with quote
Ah right ok, do you think for 150 thats a good deal ?
Would the dtx spacers help me atall, as he still has them.
Jamie.
PostPosted: 10:46 - 01 Jan 2010    Post subject: Reply with quote
Jamie.
I sold mine for £300 quid.That was for the wheels,forks,brembo caliper and front wheel spacers.
If he has the spacers then it'll be easy to fit the front wheel but you still have the problem of fitting the caliper.
Neither caliper will fit if you're planning on using SM wheels with standard forks,you have to fit dtx forks or have a caliper bracket made up...
DRZ-400sm
The last post was made 16 years, 276 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 43.45 Kb
