Help! Yamaha DTr125 Electrical power suddenly died
phill07
PostPosted: 17:08 - 02 Jan 2010    Post subject: Help! Yamaha DTr125 Electrical power suddenly died Reply with quote
hey, i was riding my bike the other day, wen all my electricals died on my, so i went to pull over put my stand down and the bike cut out. so i tuned the ignition off then on and... nothing! but battery was still working cause my neons were working fine! so i bum started my bike and it runs fine apart from the electrically powerd powervalve! dont know wot could be the ploblem? please help? is it the CPU? FUSE? WIRING? thanks
st3v3
PostPosted: 17:17 - 02 Jan 2010    Post subject: Reply with quote
Check the fuse, but if everything else is working then then it's probably not this.
Won't be the CDI(the brains), because I get the impression it starts.
Check for any burnt wires around the part that's faulty, or any that are 'kinked' out the ordinary.
Is there any electrics working with the bike not running?
Battery charged enough?
phill07
PostPosted: 17:21 - 02 Jan 2010    Post subject: i will check... Reply with quote
im just charging the battery as we speak, i will check for those things and get back to u. thanks!!
Alexio
PostPosted: 17:22 - 02 Jan 2010    Post subject: Reply with quote
You haven't worded that very clearly. It sounds like it could just be that you pulled over and then your bike cut out - indicating that it's a bike cut off switch on your side stand that is the problem. Otherwise if some of the electrics are working (obviously you are sparking if it works after a bump start) but not others you should get it checked out by someone who knows what they are doing with electrics.
st3v3
PostPosted: 17:23 - 02 Jan 2010    Post subject: Reply with quote
Does the bike have a kill switch on the handlebars you may have knocked?
It's better to give full exact symptoms here before investigating and messing with things on the bike that are fine. Thumbs Up
phill07
PostPosted: 17:27 - 02 Jan 2010    Post subject: Reply with quote
nooo when i was riding everything electrical died, no lights, no powervalve, no dash lights ect, so then pulled over, and wen i put down my stand it has a kill switch on it n my bike cut out.
i think id know if i clicked on my kill switch.
dnt know how to explain it, everything electrical on my bike is not working!?
st3v3
PostPosted: 17:31 - 02 Jan 2010    Post subject: Reply with quote
Sounds like a dodgy connection, I've had that before.
Best thing to do, is jiggle the wiring in various places until you hit the spot where the break is, then replace that section.
does it happen when you turn left/right or over bumps; just going straight..?
The last post was made 16 years, 287 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 2.03 - MySQL Queries: 15 - Page Size: 51.43 Kb
