caustic soda for cleaning carbon off valves
el_oso
PostPosted: 23:34 - 03 Jan 2010    Post subject: caustic soda for cleaning carbon off valves Reply with quote
should be fine yay or nay?
Duke 390
Car: Jeep Wrangler 4.0L
ZRX61
Victor Meldrew
PostPosted: 06:03 - 04 Jan 2010    Post subject: Reply with quote
So long as they are in a jar & not still in the cylinder head..
If they are still in the head, use nitromors.
smegballs
PostPosted: 13:31 - 05 Jan 2010    Post subject: Reply with quote
Thats right, keep the soda well well away from all things alloy. It will happily go on nom nom into your cylinder head with predictable results.
c_dug
PostPosted: 17:48 - 05 Jan 2010    Post subject: Reply with quote
We're doing the valves at the moment and there is some really solid light colour stuff on the valves that the caustic soda isn't getting off, apparently this is the cylinder that had the leaky valve seal.
Any idea what the stuff is and how to get it off? It's even a struggle to scrape any off with a screwdriver or wire brush it is that hard.
This is the exhaust valve side only by the way, and the lighter coloured stuff is on all of the exhaust valves, just a lot worse on the one that was leaking.
c_dug
temeluchus
PostPosted: 17:26 - 06 Jan 2010    Post subject: Reply with quote
just be careful not to ruin the stem when your trying to clean it up.
smegballs
PostPosted: 02:59 - 07 Jan 2010    Post subject: Reply with quote
I've cleaned valves with a wire brush in a cordless drill easily. Obviously the battery drill spins rather slow compared to a bench grinder so may give the valves an easier time. About 15 secs a valve was all that was needed to have them nice and clean.
Brass wheel on steel valve took all the carbon of nicely without posing too much risk to the valve itself.
temeluchus
PostPosted: 10:00 - 07 Jan 2010    Post subject: Reply with quote
When wire wheel was mentioned, I had visions of someone attacking the valve with a steel brush on a bench grinder Very Happy
Cigaro
PostPosted: 12:45 - 07 Jan 2010    Post subject: Reply with quote
Sorry to hijack the thread, but in a similar vein, I have a piston that's totally black in my bike.
Is it worth cleaning up the piston before I put the new valves, head and cam on?
Will that mean taking the piston out of the engine, and what should I use?
smegballs
PostPosted: 17:42 - 08 Jan 2010    Post subject: Reply with quote
I wouldnt use any rotary tools for the piston. I'm very edgy with alloy as its all too easy to erode it.
A hardwood scraper to remove most of the carbon. Probably then use a soft brass handbrush to clean it up a bit more. Should get a decent enough finish off the brass brush. Could go mental and polish with fine wet/dry and then autosol if you felt that passionatley about it I guess.
ZRX61
Victor Meldrew
PostPosted: 06:43 - 09 Jan 2010    Post subject: Reply with quote
Nitromors will dissolve carbon etc & leave the piston looking like new.
robocog
PostPosted: 11:49 - 09 Jan 2010    Post subject: Reply with quote
Whenever I've done top end stuff the procedure has been
Put piston to close to the top of the bore and smear grease round the edge of the piston to stop bits getting in
scrape any piston crown carbon off with something softer than the piston crown
I've never bothered to polish them, just get them clean enough to check they look ok and any bits that could break free are no longer a threat
When done cleaning turn crank so piston comes down the bore and wipe the carbon encrusted grease out
repeat for other cylinders
I guess the reason I have never bothered to polish the piston crowns is impatienece and knowing that there are usually many valves that also need cleaning and re lapping that time becomes a pressure
If there is no pressure to get things back together and you are doing it somewhere warm or even indoors it could be taken to extremes without having to remove the pistons at little cost other than time
dremel with mini buffing wheel attachment and a steady hand?
Not sure if there are any real world gains that you would notice if you mirror finish the crowns? other than the satisfaction you did a thorough job?
The last post was made 16 years, 247 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 67.85 Kb
