Trickle charging
deltron
PostPosted: 16:19 - 06 Jan 2010    Post subject: Trickle charging Reply with quote
I tried doing a quick search but could not find an answer to my question,I invested in a trickle charger yesterday for my nsr.I just wanted to clarify whether or not I should disconnect the battery from the bike incase of damage to the alternator? The charger has a feature where it will charge the battery to 13.5v then discharge it to 13v and start charging again to guard against overcharging if that helps. Thanks
27cows
PostPosted: 16:24 - 06 Jan 2010    Post subject: Reply with quote
Yep, disconnect the battery from the bike before charging. Never actually tried charging one still connected, but I would imagine it's not advisable.
Blue_SV650S
PostPosted: 16:45 - 06 Jan 2010    Post subject: Reply with quote
Optimates and the such charge on the bike, if your charger is voltage sensitive (not just going to boil the battery to oblivion), so can't see it doing any harm.
Go for it Thumbs Up
DeeTee
PostPosted: 22:24 - 06 Jan 2010    Post subject: Reply with quote
Go for it Thumbs Up
+1, just charge it on the bike all bike electrics will be off anyhow with the key turned off.
lonie This post is not being displayed because the poster is banned. Unhide this post / all posts.
Alexio
PostPosted: 01:16 - 07 Jan 2010    Post subject: Reply with quote
lonie wrote:
if in doubt remove the fuse(s)
I can kind of understand why you would say this but if you think about it what are the fuses for?
To protect components that's what! And if a fuse was in danger of blowing then I'd rather have it there to protect my bike than not there! If you mean remove the fuse to take away the situation of electricity reaching components in the first place then I would hope a turned off ignition would do that anyway.
SlimRick
PostPosted: 07:50 - 07 Jan 2010    Post subject: Reply with quote
Always left mine connected while trickle charging.
Handsome
PostPosted: 17:52 - 07 Jan 2010    Post subject: Reply with quote
The Optimate Trickle Charger I bought came with a few sets of leads, one of which was a set that you can connect to the battery and leave on there, you just tuck them under the seat, they are for leaving the bike on trickle charge overnight if you so wish whilst it's parked in your garage without the hassle of taking the battery off all the time...
I've used it many a time on the three bikes I've owned to no ill effect... Thumbs Up
deltron
PostPosted: 16:50 - 08 Jan 2010    Post subject: Reply with quote
Thanks for the replies everyone,I put it on overnight whilst still on the bike and it seems ok. The only reason I did not want to disconnect the battery was in case my immobiliser did not like it as I'm not sure how to reset it etc but not a problem now,thanks all.
The last post was made 16 years, 253 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.62 - MySQL Queries: 13 - Page Size: 64.47 Kb
