| Billing |
 Billing World Chat Champion
 Posted: 15:10 - 05 Jan 2010 Post subject: TZR125R Calipers - SOLVED |
Hi, I'm starting a project within a project, I need to know what calipers are a direct replacement for a TZR125R front caliper. The standard one is a 2 pot, so I'm assuming a TDR250/TZR250 would fit ok?
Also are there any fork yokes that will take the forks? I need the lower one if anybody has one lying around  ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
| Billing |
 Posted: 17:02 - 05 Jan 2010 Post subject: |
I think its either 4DL or 4FL, it's got USD forks, just need a caliper to fit them  ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
BCF Eastern members map here ---> g.co/maps/2tm8b PM me to be added to it! |
| Billing |
 Posted: 18:39 - 05 Jan 2010 Post subject: |
Cheers Keith, I'll see if I can find out what the forks came from. Does it matter whether I match calipers and forks (e.g brembo and italian forks) or will they both fit? All I really want is a caliper that would fit over the disc and match the fork bracket.
Blue spot calipers, are they off an R1/R6? I've not looked at prices, but a TZR125RR twin pot made by Sumimoto is £35
Sorry about all the questions, but I want to get it so everything works as it should, I'll post up pics of how my idea is going not seen a 2RK with USD front end before, so I have nothing to go on XD ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
 Posted: 18:47 - 05 Jan 2010 Post subject: |
Looking on Bikepics it looks like the Brembo calipers used on the TZR had the small bolt spacing (~40mm I think) so they wouldn't bolt on.
If you can get the right caliper for £35 then that is probably best rather than faffing round with alternatives (after all, you might find something cheaper, and then cost yourself more than the difference just for a different brake hose).
| Billing |
 Posted: 17:10 - 06 Jan 2010 Post subject: |
I've had word back, it appears that these are the 4DL Forks I'm looking at, so the mounts are indeed 40mm apart.
I'm waiting on hearing about the Sumimoto one, if thats not 40,, do you know any that would fit? I'm hoping a TZR250 3XV might do the job, if not I'll look for a 4DL being broken ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
| Billing |
 Posted: 20:38 - 06 Jan 2010 Post subject: |
Cheers Keith, 've had a look at Ducati calipers which are far to expensive to be quite honest.
I've been looking at RS125 and Mito Evo 125 calipers, which look like they have the correctly spaced mounting holes, heres a link to the Mito one
https://cgi.ebay.co.uk/CAGIVA-MITO-125-94-07-BRAKE-CALIPER-FRONT-BREMBO_W0QQitemZ390139230819QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item5ad61c3a63
sorry to keep asking questions, just want my idea to work properly  ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
| Billing |
| Billing |
 Posted: 18:44 - 12 Jan 2010 Post subject: |
Hi, bought a caliper, hose and master cylinder for a 4DL, so no need to play around trying to find the right size m/c.
and at £6.50 it was a bargain  ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
The last post was made 16 years, 285 days ago. Instead of replying here, would creating a new thread be more useful? |
