Teach me the basics of skiing!
PostPosted: 23:38 - 06 Jan 2010    Post subject: Teach me the basics of skiing! Reply with quote
Ok, I have some skis here. I actually got them from freecycle to make a sledge, but reckon I might as well have a quick play skiing, what with there being snow everywhere!
I don't have any kit, but the skis seem to hold my normal goretex army boots ok.
So, what stuff should I do/try to start?
Thinking very basics - I have never skied before and got quite scared when I tried them on, on my driveway.
Pointing me to an actually-useful guide on the net is fine - have googled a bit, but not sure which are good and not, etc.
(And yes, I know most things recommend you get taught 'properly', but quite possible I'll never do it again.)
PostPosted: 00:35 - 07 Jan 2010    Post subject: Reply with quote
Right. I'm shit at ski-ing but can go down a slope without falling on my arse (most times) so I should be a good teacher for a total beginner?
The metal edges of the skis are what gives you control. These are what grip the snow.
The flats are what slides.
So. If you stand with the skis paralell and flat, you'll slide fast as fuck then fall over with no way to stop (this'll be what scared you).
Oh yeah. Falling over. Don't be afraid to fall over. It is a very quick and reliable way to stop, set the bindings on the skis so they come off fairly easily. Your knees will thank you. Try to fall so you are uphill and the skis are downhill.
So, having established that paralell and flat is ideal if you want to go fast as possible with no control whatsoever, how to go slower.
For beginners, they teach "snowplough". Keep your knees together, point the tips of the skis towards one another and rotate both your feet inwards (pronate them both) so the inside edge of each ski is in contact with the snow in a v-shape.
The idea is that the edge of the ski is sliding across the snow, gripping it and slowing you down. Direction control is achieved by making one edge dig in more than the other.
Poles are unecessary at this stage but handy to help you get up.
Once you've mastered snowplough, you are in control and can try for paralell turns. I can't do these but the concept is that you keep the skis paralell and use the outside edge of one ski and the inside edge of the other to control your descent (pronate one foot, supinate the other). You zig-zag your way down, the poles provide stability, especially when going fron a zig to a zag.
It is quite rare to slide straight down a hill with both skis paralell (except when speed ski-ing/jumping). You go far too fast and are out of control. Watch skiers, even downhill racers and they kind of tack down the hill in a series of sweeping corners.
Oh, and British snow is widely considered to be among the fastest and most difficult to ski on in the world due to it having large ice crystals and being fairly compact and hard when ski-able on. If you can ski on a Scottish ski slope, you can ski anywhere.
Redoko
PostPosted: 00:41 - 07 Jan 2010    Post subject: Reply with quote
Stinkwheel you should be an instructor... Shocked Thumbs Up
Paivi
PostPosted: 01:40 - 07 Jan 2010    Post subject: Reply with quote
Are these downhill, telemark or cross country skis?
PostPosted: 09:55 - 07 Jan 2010    Post subject: Reply with quote
Cheers Stinkwheel, very useful Thumbs Up, any tips on body positioning?
Erm, I have no idea, how would I tell?
MaybeGuy
PostPosted: 10:09 - 07 Jan 2010    Post subject: Reply with quote
you cant learn to ski from the internet.
on the rare occasion i had to teach a skiing lesson, you'd be suprised how many people were like ''i read this somewhere'' or ''my mate says'' and try that rather than the way they're being taught.
just go to a dryslope and have 1 lesson. that £20 odd will get you doing basic step turns and stopping unless you're fat or have no coordination.
if you're too proud for that, watch that episode of southpark where they get a free weekend to buy a timeshare in some resort somewhere.
french fries, pizza etc. tips inwards, tails outwards and bend your knees to stop.
basic position is knees slightly bent, centre of gravity balanced, ie: not excessive weight on front or back of boot. applies at all times, so you'll lean further forwards when you're going faster, less so when going slower etc.
turning is weight on the outside leg and put that leg forwards, then step the trailing leg back in line once you've turned otherwise you end up in a heap.
carve turning is just using the edges to turn.
it doesnt really matter what type of skis they are, unless they're telemark skis, in which case the thread wouldnt be titled ''i want to learn to ski'', it would be ''wtf are these things that look a bit like skis?''
if they're about 10 foot long it might make things difficult, or 6 inch wide powder skis. basically, same with snowboarding, should be about chin height up to about head height. shorter skis are more twitchy but better to chuck around, long ones are the opposite. same as bike forks really.
PostPosted: 10:43 - 07 Jan 2010    Post subject: Reply with quote
It's not so much pride, but that I'm going to make the skis in a sledge of some kind for the weekend hopefully and just wanted to have a 'play' beforehand. If I was going to a slope, I'd probably hire all the kit anyway and have to do it at the weekend or later, making the whole idea a bit redundant Smile.
I was actually planning to go to Milton Keynes X-scape at some point, primarily for indoor skydiving, but was thinking of getting a snow boarding or skiing 3 hour lesson then.
Cheers for the general tips Thumbs Up.
Skudd
PostPosted: 10:44 - 07 Jan 2010    Post subject: Reply with quote
It's years since I went skiing, many a month spent on the slopes. Too unfit to do it now though.
MaybeGuy
PostPosted: 10:46 - 07 Jan 2010    Post subject: Reply with quote
do snowboarding. you know it makes sense.
s44678
Guest
PostPosted: 12:05 - 07 Jan 2010    Post subject: Reply with quote
Another vote for snowboarding.
On skiis you always feel as though you should be concentrating on some bollocks or improving your technique in some area. You are never content with just going straight down a hill. You feel like you have to pick and place your route, have some sort of rhythm etc.
On a board you can just whatever the f*ck you want and it feels amazing. Straight down - amazing. Massive wide carves - amazing. Nice rhythm - amazing. No rhythm at all and just kick out random hard turns to scrub off speed - amazing.
yuri2085
PostPosted: 12:34 - 07 Jan 2010    Post subject: Reply with quote
Seconded for snowboarding, I am a lot better at skiing that snowboarding, my only real area of improvement is jumps and faster in woods.
With snowboarding once you get past the first learning curve (lots of hard falling over when you catch the 'bottom lip/edge') its very relaxing and basically, enjoyable. I am still shit at snowboarding and my skull is thanking me for wearing a helmet when I was learning outside of the beginner slopes.
Snowboarding is way cooler too, and the boots are more comfortable =]
karoshi
PostPosted: 13:26 - 07 Jan 2010    Post subject: Reply with quote
bend your legs at the knees to lean your weight slightly forwards, if you have a set of hard ski-boots you want to maintain an even pressure on the inside of the boot upper with the front of your shin
not a lot of pressure, when you're stood in the skis on a flat you're basically propping/preloading your weight slightly against the front of the skis.
having a slight bend in your knee at all times is a good starting point, your knee-joint is your shock absorber, in that, if your leg is straight and you hit a bump in the snow it will hurt and you will fall over.
as Stinkwheel recommended, keep your knees together (or at least close together when in the snowplough position) and it is important to set up the binding tension so that it takes less force to twist the rear binding off than to twist your ankle off Smile
telemark / most cross country skis have no heel binding, you strap the toe of your boot in but you can lift your heel up allowing you to make a running motion
regular / downhill skis should be slightly shorter than you are tall, and you fasten the toe and heel of your boot into the ski.. to get out of them you stand down on the rear binding to pop your heel upwards and out.
oh, don't get tempted to go learn at a dry ski slope, they're arse compared to real snow and they really hurt when you fall over, go to a snowdome if you can Thumbs Up
Very Happy
Well, I've wrestled with reality for 35 years, Doctor, and I'm happy to state I finally won out over it. - Elwood P. Dowd
Redoko
PostPosted: 14:57 - 07 Jan 2010    Post subject: Reply with quote
This.
PostPosted: 15:45 - 07 Jan 2010    Post subject: Reply with quote
Skiing/snowboarding is only an issue for if I do go to x-scape, but I have always 'liked' the idea of snowboarding, maybe from hanging around with skaters as a teenagers (though the few times I tried I wasn't great, which doesn't offer much hope Smile.)
I have skis now, so that's what I'm trying. Will try and make a sled tonight, then go to a nearby park with a bit more of a hill tomorrow Smile.
I don't have ski boots, however my army boots kinda fit in - went for my first skiing at lunch time!
Cheers for the tips, all. Didn't really get to the point I could turn, but went down (the very shallow angle of) my road ok, as well as getting a one/two-person-power tow a few times Smile.
The snow has turned all ice-crystally and wasn't nearlly as good as when it was powdery.
I only need to use two skis to start with for my sled, so hopefully it will snow at the weekend and I'll get a chance to play some more in better conditions!
PostPosted: 15:55 - 07 Jan 2010    Post subject: Reply with quote
Fail. Smile
https://www.bikechatforums.com/files/g-ski.jpg
Redoko
PostPosted: 16:09 - 07 Jan 2010    Post subject: Reply with quote
Like me, I skated for a couple years back in secondary school, I know if I went on a skiing/snowboarding holiday I'd definitely prefer snowboarding, I reckon I'd feel more comfortable on a single board, makes me feel more in control. Thumbs Up
PostPosted: 16:23 - 07 Jan 2010    Post subject: Reply with quote
I always sucked at skateboarding too though... but then I suck at ice skating as well Smile.
Anyway, I say 'win'!
https://www.bikechatforums.com/download.php?id=69731
jay12329
Dr. Evil
PostPosted: 09:26 - 08 Jan 2010    Post subject: Reply with quote
Lean forward!!!!!! Laughing
Seriously lean forward, this is where proper boots come in, you can lean forward so far that the weight is on your shins and you stay upright. This isn't a good position for skiing but is a good demonstration to learners.
I wanna play Sad Sad
J
Flip
PostPosted: 10:17 - 08 Jan 2010    Post subject: Reply with quote
Stay away from ski lifts...
https://www.apple.com/trailers/independent/frozen/
MaybeGuy
PostPosted: 10:50 - 08 Jan 2010    Post subject: Reply with quote
Another thing... Set your DIN settings to about 5 otherwise you'll probably snap your knees if you come off.
PostPosted: 12:30 - 08 Jan 2010    Post subject: Reply with quote
I've actually set them a bit lower than that, added to just using army boots, it's hopefully not a big worry.
Going to try and have a another play today on a bit more of a slope, but suspect the snow is even worse now (tried my sledge late last night and it sunk more than I was hoping.)
MaybeGuy
PostPosted: 16:39 - 08 Jan 2010    Post subject: Reply with quote
yeah...
good luck with that Laughing
try again with ski boots.
PostPosted: 16:56 - 08 Jan 2010    Post subject: Reply with quote
mattsprattuk wrote:
yeah...
Army boots take a ski binding pretty well actually. Cross country skis even more so.
Rigid ski boots are comparatively recent. Certainly not in common use until the mid to late 70's. I remember friends of my parents going off up the Lecht and Glenshee with lace-up leather ski boots and wooden alpine skis.
https://www.vintageskiworld.com/v/vspfiles/photos/products/boots/boots_trappeur_redtoe_large.jpg
MaybeGuy
PostPosted: 17:03 - 08 Jan 2010    Post subject: Reply with quote
the rigidity is the key point of the boots. i bet those old leather ones are pretty rigid. also look on the toe where the bindings attach and you'll notice its weirdly shaped to accomodate.
army boots however are not up to it. too flexible. its possible yes. you can do it in trainers, its just not easy, and no grounds to learn.
PostPosted: 17:06 - 08 Jan 2010    Post subject: Reply with quote
I've skied in British army issue combat boots.
Admittedly I'm not a great ski-er but they worked ok for going down a relatively gentle slope in snowplough.
I have firmly resolved not to go ski-ing ever again though.
I have a stated intent to die with my own knees.
The last post was made 16 years, 290 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 139.28 Kb
