Frozen radiator .... o.O
Welshd1k
PostPosted: 13:38 - 08 Jan 2010    Post subject: Frozen radiator .... o.O Reply with quote
ok my zxr has been outsie in the snow for last 2 weeks, just checked it now and the rad is fucking frozen o.O and YES i put antifreeze in it , altho the temps have been -12 ish here at night, so basicaly i need to cross my fingers and hope it hasnt cracked my block right o.O
but F me it had a whole 500ml bottle of tesco anti freeze in it
Hetzer
PostPosted: 13:48 - 08 Jan 2010    Post subject: Reply with quote
Every little helps. Not.
PostPosted: 13:51 - 08 Jan 2010    Post subject: Reply with quote
Just pray it hasn't damaged it Confused
Welshd1k
PostPosted: 13:52 - 08 Jan 2010    Post subject: Reply with quote
what im thinking. hopefully if there is damage its the rad fucked. if not. engine rebuild time Sad
doggone
PostPosted: 13:59 - 08 Jan 2010    Post subject: Reply with quote
Weak antifreeze solution tends to make mushy ice crystals rather than solid ice so should be OK, but it will overheat due to restricted circulation if run while like that.
Also most engines have plugs which pop out to relieve pressure.
Welshd1k
PostPosted: 14:04 - 08 Jan 2010    Post subject: Reply with quote
well it wont be started for 2-3 weeks untill it thored out properly tbh. + my leg is shafted atm. ligaments Fed hence it not being used
PostPosted: 14:09 - 08 Jan 2010    Post subject: Re: Frozen radiator .... o.O Reply with quote
Normally meant to be a 50/50 mix, and with a capacity of 2.3L that bottle would leave it well short of a 50/50 mix.
Welshd1k
PostPosted: 14:12 - 08 Jan 2010    Post subject: Re: Frozen radiator .... o.O Reply with quote
yeah what i guessed. just hope i aint killed her or it might be ypvs quick put together to abuse
PostPosted: 14:28 - 08 Jan 2010    Post subject: Reply with quote
Had a quick look:-
https://www.tpub.com/content/constructionmisc/TM-5-3820-245-14-P/TM-5-3820-245-14-P0178.htm
From that it would appear that even a 20% mix would keep the freezing point down to -10. With luck it hasn't frozen solid.
PostPosted: 14:32 - 08 Jan 2010    Post subject: Reply with quote
You need to sort it ASAP IMO, if you can take the engine inside and thaw it if not wrap it up in an electric blanket. If you leave it, it will partually thaw then refreeze doing more damage. If you leave it it will get worse.
Welshd1k
PostPosted: 14:35 - 08 Jan 2010    Post subject: Reply with quote
bahh cant fing move it . my path is solid ice . dont wann risk firing it up. so i guess bite the bullet and let it thaw naturally / drain it out?? disconnect all the water pipes and try let it drain ??
PostPosted: 14:37 - 08 Jan 2010    Post subject: Reply with quote
The pipes aren't the issue it's the casings where it is going to do damage try to get a heater or something on it and drain it.
Mystery
PostPosted: 14:40 - 08 Jan 2010    Post subject: Reply with quote
that reminds me i don't have any in mine but i won't be using it for a while so will mines be ok or not?
PostPosted: 14:41 - 08 Jan 2010    Post subject: Reply with quote
No it's quick likely fucked.
When water freezes it expands when it expands in a closed system it makes it a non closed system I.e. cracking parts of your engine you do not want cracks in.
Welshd1k
PostPosted: 14:43 - 08 Jan 2010    Post subject: Reply with quote
was thinking kettle but if i heat it too fast ?
truslack
PostPosted: 14:46 - 08 Jan 2010    Post subject: Reply with quote
Fan heater may be a bit safer than a kettle.
Welshd1k
PostPosted: 14:48 - 08 Jan 2010    Post subject: Reply with quote
outside in the snow o.O sounds dangerous
PostPosted: 14:55 - 08 Jan 2010    Post subject: Reply with quote
Not sure I would want to warm it up quickly (heat tends to make things expand).
If you disconnect the lower water hoses and water pump drain screw (and any other drains low in the system) then hopefully anything that melts will drain out and not be able to refreeze. If you do this make sure the stuff drains into something to collect it (antifreeze is poisonous even in very small quantities and lots of small animals will drink it).
Flip
PostPosted: 14:56 - 08 Jan 2010    Post subject: Reply with quote
Throw some table salt down on the path and get it indoors.
PostPosted: 15:09 - 08 Jan 2010    Post subject: Reply with quote
warm water might work but I think it would take a while and the last thing you wanna do is chuck a load of water in the road/your garden etc. Sort it sooner rather than later though.
IMO a kettle and hot water is a better option than leaving it.
PostPosted: 15:11 - 08 Jan 2010    Post subject: Reply with quote
You need a hell of alot of salt, I dumped half a kilo onto my path and all it did was make rice crispy noises, it was slightly less icey but still bad.
Flip
PostPosted: 15:42 - 08 Jan 2010    Post subject: Reply with quote
It's worth wasting a few quids worth of salt to get the bike inside though. Smile Although his path may be long I 'spose making it more expensive. The rice crispy noises are ace though.
Welshd1k
PostPosted: 15:49 - 08 Jan 2010    Post subject: Reply with quote
its not as simple as that. it means getting it down the path onto the main road and up a really steep hill to get it in my garrage as the garrage is behind the house.
PostPosted: 16:14 - 08 Jan 2010    Post subject: Reply with quote
Man Up Thumbs Up
Mystery
PostPosted: 16:33 - 08 Jan 2010    Post subject: Reply with quote
hey chris, if i took my rad off my bike completely and brought it in side would that stop it from fucking up and cracking? or has it fucked the engine as well already with having no anti freeze?
The last post was made 16 years, 262 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.23 - MySQL Queries: 13 - Page Size: 127.18 Kb
