| el_oso |
 el_oso World Chat Champion
| finpos |
 finpos World Chat Champion
| el_oso |
| Cigaro |
 Cigaro World Chat Champion
 Posted: 11:46 - 08 Jan 2010 Post subject: |
Looking at the manuals and parts list it looks like there is just a single long rear mounting bolt for the Divvy engine, with a nut on one end.
If it has 2 nuts on it then it suggests someone has bodged it in the past with a length of threaded rod and a couple of nuts (cheap from B&Q and the like).
How rounded is the nut? If only just rounded then it will probably come out with a half decent quality hex socket (rather than a bi-hex one).
| Blue_SV650S |
 Posted: 12:57 - 08 Jan 2010 Post subject: |
Pics please!!  ____________________ The purpose of life is to fight maturity. |
| el_oso |
 Posted: 14:29 - 08 Jan 2010 Post subject: |
looking at the bike in some proper light this morning it looks like it is just one single long rod. i've undone the nut at the other end and tried bashing it through but it just doesn't seem to want to budge. i've tried lifting the engine to different heights to get the pressure off the rod and even tried lying it on the ground and tapping it through but it hasn't budged a millimetre. i've also had a pipe wrench on it this morning and it still won't move. i thought that if it was one big rod then it should spin fairly freely at the other end but nothing so far.
https://www.mediafire.com/imageview.php?quickkey=o5yjwdlmmmi
https://www.mediafire.com/imageview.php?quickkey=dddakm523m4
https://www.mediafire.com/imageview.php?quickkey=zknzdn2zkzi ____________________ Duke 390
Car: Jeep Wrangler 4.0L |
 Posted: 14:34 - 08 Jan 2010 Post subject: |
I would suspect what has happened is that the bolt has seized to the alloy of the engine.
I would be tempted to get some decent penetrating oil (not just WD40) and try and get some on the bolt where it goes into the engine cases. Repeat this regularly for a few days . Then try a bit of heat (carefully) on the engine mounts and try putting a socket on the bolt and turning it again.
But do at least use a good quality 6 point socket. A bi hex one will just slip on that and chew it up even more.
| el_oso |
 Posted: 15:11 - 08 Jan 2010 Post subject: |
this is also what i expect has happened. there is no chance of using a socket. The socket which is was using was a high quality workshop set which belonged to my dad. been using a long pipe wrench for the last half hour after letting some wd-40 soak in while laying it on it side. also applied some heat and still no go. been applying so much force that the bike is actually lifting up off the floor
really am stuck at this point  ____________________ Duke 390
| c_dug |
 c_dug Super Spammer
| Blue_SV650S |
 Posted: 16:15 - 08 Jan 2010 Post subject: |
Looking at the rounding on that head, I think we are onto plan B!!
You might want to try a blow torch along the length of the bolt/engine casing. The heat should help you out.
My only other suggestion is to weld a bar (or old socket) onto what remains of that bolt head. If you can get some rotation on the bolt, then it will then probably 'bash' out. ____________________ The purpose of life is to fight maturity. |
| Cigaro |
| c_dug |
 c_dug Super Spammer
| Blue_SV650S |
| Cigaro |
| el_oso |
| reggie |
 reggie Spanner Monkey
 Posted: 21:19 - 08 Jan 2010 Post subject: |
| TUG |
 TUG World Chat Champion
The last post was made 16 years, 245 days ago. Instead of replying here, would creating a new thread be more useful? |
