Carbs & jets cleaning
Kris
PostPosted: 22:34 - 08 Jan 2010    Post subject: Carbs & jets cleaning Reply with quote
Hi,
I've got the carbs off the Pan euro for a clean as I think they're the cause of a lack of top-end with sluggish roll-on performance.
When I took the diaphragms off the carbs inside were filthy with lots of deposits. I reckon these carbs have never been off this bike and I want to clean them thoroughly.
What's the best way of cleaning the carbs and jets please people?
I've heard all sorts from fishing wire thru' jets tosoaking them in Acetone. WTF? Razz
Anyway, how do you clean yours?
Very Happy
www.prisonplanet.com
ish765
PostPosted: 22:43 - 08 Jan 2010    Post subject: Reply with quote
Yep. Soft NYLON fishing line.
Blast with lighter gas.
Soak in lighter fluid.
Sound OK?
I would not use any kind of wire, string maybe.
RXS100 On the Road.
lonie This post is not being displayed because the poster is banned. Unhide this post / all posts.
tatters
Exxon Valdez
PostPosted: 23:13 - 08 Jan 2010    Post subject: Reply with quote
Send them off to be ultrasonicly cleanned, no better way to clean carbs.
Ichy
PostPosted: 23:42 - 08 Jan 2010    Post subject: Reply with quote
In a perfect world you would get the carb ultrasonically cleaned and then vapour blasted.
Reality suggests that carb cleaner, hint is in the name, is an easier option.
To clean jets I remove them from the carb, spray carb cleaner into a shot glass then leave the jets in there to soak overnight.
I also stick the carb bodies in the dishwasher, much better if there isn't any salt in there.
Have you checked that the diaphragms for holes or splits?
jerryrock
PostPosted: 21:44 - 14 Jan 2010    Post subject: Reply with quote
I bought a small ultrasonic cleaner,cost around 25 euros,cleans jets and smal parts perfect.small enough to put at the back of the garage when not needed aswell,just fill it up and leave parts in it for hour.could be worth looking into.
one more cuppa and then ill start...
PostPosted: 17:11 - 15 Jan 2010    Post subject: Reply with quote
Filling it up with cheap cola gives better results than just using water.
If you don't have an ultrasonic cleaner you can soak the carbs in white spirit.
Vincent wrote:
If they,re very gummed up, a domestic ultrasonic cleaner won't cut it. It'll loosen the crud but leave it where it is.
I disagree with this. These are the results from using carb cleaner first and then using an ultrasonic cleaner with just water:
https://i15.photobucket.com/albums/a376/ms51ves3/DSC00729.jpg
https://i15.photobucket.com/albums/a376/ms51ves3/DSC01064.jpg
https://i15.photobucket.com/albums/a376/ms51ves3/DSC01065.jpg
I reckon I could have removed the gummed up petrol using just my ultrasonic cleaner and cheap cola from ASDA.
Old Git Racing
PostPosted: 20:28 - 17 Jan 2010    Post subject: Reply with quote
I borrow the wifes ultrasonic jewellry cleaner but don't tell her. Have used acetone to good effect.
The last post was made 16 years, 283 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 61.87 Kb
