Exhaust Baffle
That-Kid-O
PostPosted: 15:10 - 08 Jan 2010    Post subject: Exhaust Baffle Reply with quote
Hello there. I have a Akrapovic end can on my 600rr and a PC3, I was just wondering if the maps on the DynoJet website were designed for use with the baffle inserted or removed? And will there be a power loss by removing the baffle?
That-Kid-O
PostPosted: 00:47 - 09 Jan 2010    Post subject: Reply with quote
Please help?
baldy
PostPosted: 01:55 - 09 Jan 2010    Post subject: Reply with quote
You would be better getting a custom map made, the ones they supply are just a kind of average map for that kind of setup. I don't think you will notice any difference in power anyway. I didn't on the 1000rr. I just play with the maps a little to see what makes it feel better or worse.
One day i will rule the world, just not today.
That-Kid-O
PostPosted: 02:27 - 09 Jan 2010    Post subject: Reply with quote
Thanks baldy. Although you say no power gain/loss will be noticed does the removal of the baffle make a difference when using a PC3?
smegballs
PostPosted: 10:07 - 09 Jan 2010    Post subject: Reply with quote
I thought one of the pro's of EFI was that for small changes like a baffle or air filter swap it sorts itself out with all its sensors?
baldy
PostPosted: 17:34 - 09 Jan 2010    Post subject: Reply with quote
Normally with a pc you disable one of the sensors that let the ecu's map change slightly depending on conditions. It's not always put in though as it says for track use only. (It's a little connector that looks like a tooth that plugs into where the lambda sensor goes.) I have played with the maps a fair bit and not noticed any difference in power, it just changed the throttle response.
That-Kid-O
PostPosted: 17:40 - 09 Jan 2010    Post subject: Reply with quote
So all in all will the stock engine/injectors be able to detect the change casued by the removed baffle and alter mixtures?
baldy
PostPosted: 17:52 - 09 Jan 2010    Post subject: Reply with quote
It is the lambda sensor that detects if the engine is running as it should. It can only adjust by a small amount. I have run my blade for 3 years on a map that is probably miles out and the bike runs just fine.
I wouldn't worry about it at all, unless the bike ran like a dog and it kept over heating.
Blue_SV650S
PostPosted: 18:19 - 09 Jan 2010    Post subject: Reply with quote
I'd ring/email power commander, it is the only way to get the definitive answer really ...
At a guess (and it is only a guess) I'd say baffles-out! Thumbs Up
That-Kid-O
PostPosted: 18:57 - 09 Jan 2010    Post subject: Reply with quote
Thaks for all the help everyone. I think I will just remove the baffle from now (33BHP restricted at the mo) and keep em out when the PC3 comes depending on what DynoJet say when i email them Wink
The last post was made 16 years, 243 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 62.83 Kb
