Valve clearances problem
The Artist
PostPosted: 10:23 - 11 Jan 2010    Post subject: Valve clearances problem Reply with quote
2 thing people.
1. Does anyone know the valve clearances for a suzuki gs 125 1983 kickstart only model.
EDIT: Found these on the internet, do they sound about right?
0.08mm and 0.13mm
2. How do I do the clearances when I take the rocker covers off and the rocker arms are at such and angle, I can't get a feeler guage in the gap flat, I would have to bend them.
Yes the engine is in the correct position but I don't see how to do it.
Thanks Karma to all who help
PostPosted: 10:29 - 11 Jan 2010    Post subject: Re: Valve clearances problem Reply with quote
The answer is in the question.
Or buy pre-bent ones.
https://ecx.images-amazon.com/images/I/41ap2N0hHHL._SL500_AA280_.jpg
The Artist
PostPosted: 10:31 - 11 Jan 2010    Post subject: Reply with quote
So there is no knack to it, I just have to get bent ones Laughing
PostPosted: 10:37 - 11 Jan 2010    Post subject: Reply with quote
You can bend normal ones too, but if you keep bending and straightening them, they will snap.
They sell angled ones in Halfords and most other auto parts suppliers.
I've had some engines where they were so tight to get in, I had to snap a piece off the end of the feeler guages and use that.
PostPosted: 10:48 - 11 Jan 2010    Post subject: Re: Valve clearances problem Reply with quote
0.08mm and 0.13mm
That is what is given in the old Autodata book I have. Inlet and exhaust clearance between 0.08 and 0.13.
Damon
PostPosted: 11:42 - 11 Jan 2010    Post subject: Re: Valve clearances problem Reply with quote
0.08mm and 0.13mm
They are both the same? How come?
PostPosted: 11:51 - 11 Jan 2010    Post subject: Reply with quote
Good question, but that is what is listed, and for other bikes using virtually the same engine. And the same for newer manuals for newer versions of that engine.
Maybe the exhaust valve is well cooled. Maybe the inlet valve is longer. Both would affect the comparative clearances.
Although suspect more likely they are not that worried either way.
The Artist
PostPosted: 12:18 - 11 Jan 2010    Post subject: Reply with quote
I know the principles of valves and have done valve timing diagrams and set them on big diesels but these are a PITA.
My feel guages won't bend without snapping, I even tried the thinnest ones in a combo but still won't work.
I believe exhaust clearance is bigger because it opens before the end of the power stroke, all the way up the exhaust stroke and can overlap with the inlet valve opening aswell.
PostPosted: 12:24 - 11 Jan 2010    Post subject: Reply with quote
Quite normal for there to be some overlap between exhaust and inlet valve.
PostPosted: 14:36 - 11 Jan 2010    Post subject: Reply with quote
As a gebneral rule with those small, simple aircooled japanese singles. As long as there is a gap of some sort, even a very tiny one, you are usually ok. It's when there is no gap at all you run into problems.
Damon
PostPosted: 16:09 - 11 Jan 2010    Post subject: Reply with quote
The exhaust clearance is generally bigger as it has a higher volume of gas to let out of the cylinder. Gas expands as it warms Thumbs Up
PostPosted: 16:24 - 11 Jan 2010    Post subject: Reply with quote
Exhaust clearance shouldn't really be affected by needing to get more gas out (most bike seem to have more intake volume than exhaust, ie the 5 valve Yamahas had 3 inlet and 2 exhaust valves).
Think that the normal reason the exhaust valve clearance is greater is that the hot exhaust gases heat up the exhaust valve more, and as it is heated the valve gets longer. The wider clearance allows it to still close when it is longer.
TUG
PostPosted: 16:43 - 11 Jan 2010    Post subject: Reply with quote
I always thought this was the case, atleast it was what i was taught on car engines. I need to ask my mentor to show me how to do clearances again, i dont get chance to touch engines much and i must admit it bothers me somewhat. Knowledge is invaluble and i want as much of it as i can get.
Haz ER-5, innit!
Damon
PostPosted: 15:40 - 12 Jan 2010    Post subject: Reply with quote
Fair enough, I stand corrected. Im just repeating what my mentor said (doing a "Advanced motorcyle mechanic" course. I also heard that there are sometimes more inlet valves as it is harder to get the air into the cylinder than out of the cylinder via the exhaust.
PostPosted: 15:49 - 12 Jan 2010    Post subject: Reply with quote
Think the amount of flow of the inlets vs the exhausts is a design issue which isn't fully settled. Some take the view that who cares about the exhaust, it will find its own way out. From memory rule of thumb is something like 2/3 the flow on the exhaust as the inlet (but that is from memory, and a rough figure anyway).
Might be that your mentor misunderstood the question (ie, mixed themselves up with more flow and more heat). A wider clearance would mean the valves are open for less time and so reduce flow (ie, the cam would have to turn a few more degrees to take up the slack before opening the valve).
Damon
PostPosted: 16:24 - 12 Jan 2010    Post subject: Reply with quote
Thanks for clearing that up for me Keith
Damon
Quote Me Happy
PostPosted: 16:26 - 12 Jan 2010    Post subject: Reply with quote
I've had success with Motion Pro feeler gauges in the past when faced with very resticted access. They're really quite small and will fit into the smallest areas with ease.
I picked the ones I needed up from eBay for not much money.
The last post was made 16 years, 259 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.03 - MySQL Queries: 13 - Page Size: 100.31 Kb
