| Cigaro |
 Cigaro World Chat Champion
 Posted: 11:37 - 16 Nov 2009 Post subject: Shock mounts in a bad way - what are my options? |
Whilst fitting the rear shocks back on to the GN last night I noticed that two of the nuts were very hard to get on, as in they kept slipping off the mounting stud when I first put them on.
I did eventually manage to get them on, but they were very stiff to tighten up.
Looking at it it actually seems that the right hand side top mount stud has had some of the thread snapped off and there is a smaller nut installed on it.
It seems sturdy now it's all bolted up (the nuts aren't going to come off the stud, in other words); is this dangerous? If so, I'm assuming I need to replace the shock mounting studs on the swingarm and frame; Can I just cut off the existing stud , drill the hole through and use a bolt with washers to get the spacing correct or does it need to be welded on (I'm assuming it probably does as otherwise the bolt will move around in the hole!)
Who will do this for me and how much will it cost?
Cheers.
| Cigaro |
 Posted: 11:46 - 16 Nov 2009 Post subject: |
| ms51ves3 |
 ms51ves3 Super Spammer
| Cigaro |
| ms51ves3 |
| Vincent |
 Vincent Banned
| Cigaro |
| Robby |
 Robby Dirty Old Man
| Vincent |
 Vincent Banned
| Cigaro |
| 27cows |
 27cows World Chat Champion
 Posted: 21:47 - 12 Jan 2010 Post subject: |
I think I'd be tempted to have threaded bit recut to the next size down (maybe to take a non-metric nut). Using a bolt in place of the lug isn't an option - it's extremely unlikely to work and could make a nasty mess of your frame.
You should be able to do it yourself with no bother if you have a tap and die set (and the obligatory big box of assorted fasteners from many sources that most of us seem to acquire ). Obviously care would need to be taken. But this should work as it would only be the thread part that was being slightly thinned, while the main body of the lug, which takes the weight, remains untouched. |
| finpos |
 finpos World Chat Champion
| Vincent |
 Vincent Banned
| Frost |
 Frost World Chat Champion
| Ariel Badger |
 Ariel Badger Super Spammer
| Damon |
 Damon World Chat Champion
| Cigaro |
| Damon |
 Posted: 08:04 - 13 Jan 2010 Post subject: |
How about getting the original nut on it and then drilling through both the nut and shaft to accept a split pin. Best of both worlds  |
| 27cows |
| Cigaro |
 Posted: 10:43 - 14 Jan 2010 Post subject: |
Cheers everyone. Well, someone I know who is an experienced mechanic and engineer is going to drill and tap the stud and put a bolt through the middle of it, that seems the best way to do it now.
Many thanks for your help  |
The last post was made 16 years, 279 days ago. Instead of replying here, would creating a new thread be more useful? |
