head stock help
webhead
PostPosted: 14:14 - 13 Jan 2010    Post subject: head stock help Reply with quote
hello there im trying to change a front end ,never done it before the probs i got is the forks i want on the headstock is thinner so bearing cups arent big enough ,anyone know what i can do,
im just scratching my head getting no where fast lol.
cheers.
virus
PostPosted: 14:30 - 13 Jan 2010    Post subject: Reply with quote
What forks are you trying to put into what bike?
Im assuming your using the yokes and stem that match the forks.
John
own: 81 xs1100g...
webhead
PostPosted: 14:51 - 13 Jan 2010    Post subject: Reply with quote
hi yes the cup has to be 48mm wide and the stem that goes init is 23mm according to my vernier,i have seen some tapered roller bearings that have a cup cone 48mm and the bearing is 25mm nearly right but i need 23mm bearing and cone to match do you know anyone that sells a range of them cheers.
virus
PostPosted: 16:05 - 13 Jan 2010    Post subject: Reply with quote
Im in the middle of a bearing conundrum very similar myself, Ive discovered that for a 48mm OD the standard ID is 25mm, and anything other than that is rare and expensive.
Try www.simplybearings.co.uk
John
own: 81 xs1100g...
Robby
Dirty Old Man
PostPosted: 17:03 - 13 Jan 2010    Post subject: Reply with quote
If you're fitting the yokes from a different model onto your bike, one way to make it all go together easily is to swap the stem. You should be able to get it pressed out of one set of yokes and pressed into another.
I knew a guy that was doing this to a Triumph Daytona front end onto a Suzuki VX800, to take advantage of a 17" front wheel and twin discs.
webhead
PostPosted: 10:20 - 14 Jan 2010    Post subject: Reply with quote
thanks for help, i think im going to have to go with the 25mm 1,s and just make a kind of sleeve over stem so bearing can then sit on that should work ,i hope lol ,is that a good idea or dodgy idea?????????????
27cows
PostPosted: 12:10 - 14 Jan 2010    Post subject: Reply with quote
It's a good idea if you can make it work LOL But be careful.
The last post was made 16 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.21 Sec - Server Load: 1.56 - MySQL Queries: 13 - Page Size: 59.79 Kb
