suzuki gn250 big bore kit any thoughts?
jake47
PostPosted: 10:44 - 14 Jan 2010    Post subject: suzuki gn250 big bore kit any thoughts? Reply with quote
Hi first post here so be nice.
I have a suzuki gn250cc c 1992 , and have ordered a big bore kit from e bay from a chinese seller here https://cgi.ebay.co.uk/GN300-GN250-BIG-BORE-cylinder-Improve-performance_W0QQitemZ270514614149QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item3efbed6f85 as you can see it states it ups the power to 300 cc.As ime not too used to working on bikes , well for some years anyway i wonder if anyone else has used the above and what are your thoughts.
is it going to be fairly straightforward to do the job or is it going to be a bike mechanic ? as cost is important i would like to have an attempt at doing the job myself but am a bit wary, could this kit do permanent damage and if so i suppose i could replace it with the original bore and piston etc.What do you think?
27cows
PostPosted: 11:23 - 14 Jan 2010    Post subject: Reply with quote
The GNs are very simple and easy to work on. Shouldn't be any problem putting the 300 kit on yourself. How the engine will then run is anyone's guess, though.
smegballs
PostPosted: 11:29 - 14 Jan 2010    Post subject: Reply with quote
If you read the item location its says its in Wuxi, China. The same place that made the dodgy bikes in the other thread.....
Also they give the stated power but where is the source or is it all made up?
I'd avoid to be honest but you have already ordered it Rolling Eyes
Its simple in theory but head will need to come off and so the cam will need re timing which if you haven't done before can be tricky.
Also your fueling will now be out so prepare to have fun dialing in the jetting, thats assuming the chinese piston lasts that long Laughing.
Good luck! Be sure to report back how it goes as it would be interesting to see how it goes.
There is a gap of 1 year, 143 days between these two posts...
Minitwin65
PostPosted: 13:52 - 06 Jun 2011    Post subject: Reply with quote
I too bought the 300cc kit and some race engine builder mates said it looks fine. It`s fitted and works ok but there is no power increase yet because it has not been re-jetted. They have a gearbox sprocket Dyno and will set it up for me soon. I`ll let you know how it goes.
I`m very religious, every Sunday I get on my knees and thank God !
Livefast123
PostPosted: 14:09 - 06 Jun 2011    Post subject: Reply with quote
Judging by how much power the new Chinese 250's offer I wouldn't hold out much hope of a power increase as even though the barrel may be of OK chinese metal the quality of the porting etc is what makes the power along with the cc.
Job should be fairly easy apart from the cam/valves and timing etc.
Just bought a chinese piston to rebuild the NSR and TBH the quality is shi*t but it suited my financial circumstances and it works....so what if it lasts 1000 miles less than the Honda part.
Fair play to you though for giving it a shot and it'll be interesting to see how it comes out.
Current ride - Yamaha MT-07
PostPosted: 14:15 - 06 Jun 2011    Post subject: Reply with quote
It is a 4 stroke so the barrel should be pretty simple. No porting to care about. Could be interesting to see what the compression lands up as.
As to a cheap piston in a 2 stroke, it isn't it lasting 1000 miles less than a stock one I would worry about, it is it lasting 1000 total at best. About the life expectancy of cheap pistons in my MBX125 many years ago (ie, they just about survived running in).
hellbound
PostPosted: 15:28 - 06 Jun 2011    Post subject: Reply with quote
Ok, this is handy, when it all goes wrong and your engine explodes I have a GN250 kicking around that I need shot of!
May you always see the road rising up to meet you and your enemies defeated in the mirror behind.
RatbikerNate
PostPosted: 12:12 - 11 Jun 2011    Post subject: Reply with quote
I've had one of these GN300 barrel kits fitted to my bike for well over a year now, it's done about 15,000 miles now, many of which were hard miles across the most mountainous roads in europe and switzerland.
(My GN300 chopper and my mates sidecar in the Italian Dolomites 2011)
https://i245.photobucket.com/albums/gg50/RatBikerNotts/mongwayround2011/P1020697.jpg
About a month ago I had to work on the engine (bottom end had finally worn out after 60 odd thoudand miles) and to my supprise the barrel and piston were still in fantastic condition.
Based on actual experience I can recommend these kits.
Further information:
When running in the piston I used this method:
https://www.mototuneusa.com/break_in_secrets.htm
And I run it with standard airbox, straight through exhaust and a 135 main jet.
With uprated gears (17t front and 41 rear....if i remember rightly) it gives a cruising speed of 70, overtaking speed of 85, and better acceleration. Oh and delivers an average of about 85-90 mpg
RatbikerNate
PostPosted: 12:20 - 11 Jun 2011    Post subject: Reply with quote
Wanna sell me the carb? My diaphragm's gone tits up.
humanbeing This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
croftys gamma
PostPosted: 16:40 - 22 Jul 2011    Post subject: Reply with quote
Boredom is a terrible thing, it makes you do all kinda pointless stuff....like wanting to put a GN250 engine in a GS125 (which I'm restoring right now).....but will it fit? I need a cheap, better still, free, GN250 engine to try it, even if its fragged,if it does then I'll buy a snotter of a GN250 so I have the carb, wiring and CDi.....then maybe put a 300 Top end on it (wonder if the DR350 will fit?!)
So, Hellhound......do you have this engine? Where are you and what do you want for it?
The last post was made 14 years, 140 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.45 - MySQL Queries: 13 - Page Size: 71.25 Kb
