Fuel tank size
c-m
PostPosted: 17:59 - 14 Jan 2010    Post subject: Fuel tank size Reply with quote
My bike has reasonable sized fuel tank at 19 litres and town to town riding sees a range of about 180miles.
I was looking at some Ducati's and similar bikes and their tanks are only 15 litres or so. This give the bike and truly awful tank range.
When MotoGP bikes, where weight is crucial have a 22litre tank, why aren't modern road going sports bikes designed with that sort of capacity?
The Artist
PostPosted: 18:05 - 14 Jan 2010    Post subject: Reply with quote
MotoGP bikes are not comparable to road bikes. Their tanks have to hold enough fuel for one race as they cannot refuel. Their tanks will be sized up against the engine fuel consumption in each race.
Alexio
PostPosted: 18:23 - 14 Jan 2010    Post subject: Reply with quote
Get a BMW? There are some which have tanks (probably after market) that are like 36 litres.
400bandit
PostPosted: 20:40 - 14 Jan 2010    Post subject: Reply with quote
Don't get a Firestorm. Supposed to have a 15 or 16 ltr tank but I have not been able to get 14 in even when running on vapors!
Couple that with pretty bad fuel consumption = not but a lot of fun and noise...
Joe
PostPosted: 21:18 - 14 Jan 2010    Post subject: Re: Fuel tank size Reply with quote
MotoGP bikes need to burn a hell of a lot of fuel to make a lot of power. They also probably have some sort of fuel foam to prevent excessive slosh. Probably got less general 'road gunk' to take up space around the bike too.
Most riders don't need/want a bigger tank, as they'll usually want to stop for a break by then anyway, definitely if we're talking sports bikes, which, to be fair, are designed for 'sports' Smile.
My KTM manages about 100 miles before reserve on the stock 12l tank, but I've got an extra 14l on it too. CCM has 11l and the KTM200 has an 'extra big' 9 or 11l (stock is 7l or something.)
Obviously fuel economy needs to be mixed with the fuel tank size to get a good idea. Kawashima posted up an interesting spreadsheet on this sort of thing recently.
c-m
PostPosted: 21:43 - 14 Jan 2010    Post subject: Reply with quote
My point was though that if they can get a 20+ litre fuel cell onto a motogp bike and still keep the weight low, areo dynamics and ergonomics, then they could easily include a that size tank on something like a ZX9R.
100miles before reserve on the KTM is a very short distance in modern terms.
PostPosted: 21:56 - 14 Jan 2010    Post subject: Reply with quote
But without the fuel foam, you'd get more slosh, compromising handling with a less full tank. As I say, I also suspect that a road bike has more general *gubbins* taking up space. They also have to have some consideration for 'wet weight' tests, which are biased by more fuel, as well as just the fact people will often fill their tanks up, leading to marginally reduced performance (handling and power.)
rac3r
PostPosted: 22:40 - 14 Jan 2010    Post subject: Reply with quote
My full tank costs about £10ish and I get about 100 miles before the reserve light comes on or 95 with 'messy' riding Laughing
Chequered Flag
Jamie S
PostPosted: 22:53 - 14 Jan 2010    Post subject: Reply with quote
Had to switch to res last night on the dt after just 65 miles !
I really need to have a play about with the gearing a bit, 70mph at 9k (red line starts at 10) isn't doing a whole lot of good for my fuel economy
Jamie S
The Artist
PostPosted: 23:58 - 14 Jan 2010    Post subject: Reply with quote
I can get well over 200 miles from my tank.
PostPosted: 00:40 - 15 Jan 2010    Post subject: Reply with quote
I just found out that my Honda Chaly tank is 1.8 litres Laughing Honda claim it's 2.8 litres.
Alexio
PostPosted: 05:24 - 15 Jan 2010    Post subject: Reply with quote
1.8 litres is what, 80 miles? Razz What ever it is, it's going to be plenty for the Chaly. Also, fuel certainly affects my 125's performance. A full tank means a whole 10MPH less on some roads.
Itchy
PostPosted: 06:06 - 15 Jan 2010    Post subject: Reply with quote
Get some adventure rider tanks>?,
Walter had a tank strapped to the side of his X challenge, David Lambeth makes them for £75 they are sort of like coke bottles but bigger which you plumb in via a tri pipe.
c-m
PostPosted: 10:38 - 15 Jan 2010    Post subject: Reply with quote
Can you get longer range tanks for supersports?
PostPosted: 10:45 - 15 Jan 2010    Post subject: Reply with quote
Isn't that below the min delivery for many petrol stations?
Alexio
Searching Google suggests no.
You can always fill a jerry can and put it in your rucksack Thumbs Up (obviously not for track use unless you're feeling particularly brave and stupid)
There seems to be some contention about that. Pumps normally state 2L min delivery but many stations don't mind less according to anecdotal evidence. Still, it's not really an issue. Just fill the remainder in to one of those green petrol tanks and take it home. Use a 550ml plastic coke bottle even Thumbs Up
PostPosted: 10:51 - 15 Jan 2010    Post subject: Reply with quote
Don't get caught!
PostPosted: 11:07 - 15 Jan 2010    Post subject: Reply with quote
Known plenty of people to get way under that - they just put that to discourage people from messing them about.
Dusty used to regularly get 50p of fuel for his R6, to cover a short ride Confused.
tvr321
PostPosted: 23:13 - 15 Jan 2010    Post subject: Reply with quote
Isn't it in the rules that the fuel tank on a MotoGP bike has to be a certain size?
PostPosted: 12:04 - 18 Jan 2010    Post subject: Reply with quote
Just to add a quick comment in, apparently the tank on my car is 66litres, but the fuel pump is included in that calculation, which actually stores 1.5 litres of fuel.
Dont know if its the same with bikes, but just adding some info Smile
St0rmer66
PostPosted: 22:25 - 19 Jan 2010    Post subject: Reply with quote
I think the tank can be any size they want.. they're still only allowed a finite amount of fuel though regardless! (and it would be stupid to make it too big, for weight and stupid to make it to small, you need fuel for power!).
My bike has (I think) an 18litre tank.. had the fuel light come on after around 90 miles of spirited riding! Shocked . Big twins are thirsty.
:: Honda XR 125 L ('53) => Kawasaki GPZ 500S ('02) => Suzuki SV650S ('00) => Aprilia RSV-R ('51) ::
thewildblue
PostPosted: 09:20 - 20 Jan 2010    Post subject: Reply with quote
I squeezed 19.5 litres in my 19 litre versys tank and there was still a good litre or so left in there.....
On most of my bikes Ive usually manged to get the stated amount or in sometimes more into my tank. Then again I fill up while sat on the bike rather than on the sidestand........ Wink
The last post was made 16 years, 287 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 120.63 Kb
