ThermaHelm
Bike Chat Forums Index -> Biking News & Rumours
LeeR
PostPosted: 21:23 - 15 Jan 2010    Post subject: ThermaHelm Reply with quote
Shamelessly stolen from The Rider's Digest (February edition), ThermaHelm an endothermic lining in the helmet to protect your brain during the "Golden Hour", thought it might be of interest.
My claim to fame: Austin Vince nicked my pen...
pwntifex
PostPosted: 04:14 - 16 Jan 2010    Post subject: Reply with quote
I honestly doubt this could do much to save your life if you have an accident that causes significant swelling of the brain. Presumably it is intracranial pressure, and not the brain overheating, that is the significant factor at play?
LeeR
PostPosted: 16:14 - 16 Jan 2010    Post subject: SuperSkin helmet Reply with quote
Fair enough, if that doesn't float your boat what do you make of SuperSkin helmets by Lazer?
PS> where have you been?
That_Hornet
PostPosted: 20:03 - 16 Jan 2010    Post subject: Reply with quote
Well its just using basic knowlage and applying it to the helmet.
If you have a swelling on you fist, ankle or anywhere. You stick ice on it to stop the swelling.
In a bike crash you head is going to swell inside the hot helmet that's made primarily of polystyrene, which has been used for years to keep things hot. (Loft insulation to name one)
As i have read, this is designed to keep your head cool for 40 minuted after the impact. That's a lot of time where your head is being keep cool and not swelling as much. Thus saving brain cells and minimizing brain damage.
Very good idea IMO
MattHirst
PostPosted: 19:19 - 17 Jan 2010    Post subject: Reply with quote
When you injure something, like break your arm for example it will get very swollen. This is the body surrounding the injured area with fluid to further protect it while it heals.
The main/most common type of head injury in a bike accident would either be compression (ie getting it run over by a car) or concussion, both possibly leading to a bleed in the brain. The bleed is what does the damage.
Either that or having severe trauma to the rest of the body (ie severe pneumothorax, internal bleeding etc) and starving the brain of oxygen which would lead to brain cells dying.
Regardless of how your brain was injured (in a bike accident atleast), i can't see a device that cools down your head helping matters, it could cool down the core temp of your brain to much and cause more harm than good.
Syx
PostPosted: 15:59 - 18 Jan 2010    Post subject: Reply with quote
I thought this was going to be some cool helmet with built in night vision.
Why I thought that, I'm not entirely sure! Laughing
PostPosted: 20:25 - 18 Jan 2010    Post subject: Reply with quote
Design it!! Laughing
and
PostPosted: 13:08 - 03 Feb 2010    Post subject: Re: ThermaHelm Reply with quote
The999Kid
PostPosted: 19:56 - 03 Feb 2010    Post subject: Reply with quote
The swelling surrounding an injured limb is different to that of a raised intracranial pressure in many ways...
Firstly, the swelling in the limb is a protection reaction caused by histamine and other inflammatory agents of the immune and parasympathetic nervous system to protect the limb from further damage. The cells surrounding the injury take on vast amounts of water to become turgid, or stiff and minimise movement of the site. This also helps stave off infection by reducing the available water supply, thus dehydrating water dependent pathogens.
The area surrounding the limb is also skin, a highly flexible and elastic organ that can change size and shape to accommodate the swelling and increased pressure with very few side-effects barring overactive sensory nerves.
Raised intracranial pressure due to trauma or head injury can be caused in the same manner as injuries to a limb (Multiple impacts with the skull when involved in collisions, sudden stops or forceful impacts with solid objects). It can also be increased through a bleed (haemorrhage) or blockage of the ventricular cycling ducts that recycle CSF around the brain. Both these events cause an increase in fluid levels surrounding the brain.
The Skull, unlike, skin does not have the capacity to stretch to accommodate increases in size or pressure changes within the cranial vault. The increased volume in the cranial space will then exert a force on the brain as it cannot overcome the bony fusions of the skull itself. Basically, the more liquid begins to fill the skull, the more the brain suffers. As the brain begins to be crushed inside the skull, smaller blood vessels will succumb to the increased pressure and collapse, starving the nervous tissue of oxygen, thus complicating the issue.
Now blood vessels also succumb to the cold (as everyone knows) and narrow significantly to prevent heat loss in cold conditions?. (see where I?m going?) You are proposing to narrow pretty much all surface blood vessels in the scalp and surface of the brain, increasing the effect of the raised intracranial pressure further, decreasing the time taken for neural impairment to take hold, making assessment of cognitive ability by medical persons very hard!
ThatHornet wrote:
As i have read, this is designed to keep your head cool for 40 minutes after the impact. That's a lot of time where your head is being kept cool and not swelling as much. Thus saving brain cells and minimizing brain damage.
I think you can see from my pathological breakdown of head injuries that hot and cold don?t enter into it as far as the head in concerned. If you want to incorporate the body then feel free to send me a message and ill happily go into more detail as to how ambient temperature can help maintain a patient?s blood pressure after physical trauma.
H2H
and
PostPosted: 13:04 - 04 Feb 2010    Post subject: Reply with quote
LordShaftesbu...
PostPosted: 19:09 - 04 Feb 2010    Post subject: Reply with quote
https://news.bbc.co.uk/1/hi/7815105.stm wrote:
Brain-cooling devices developed
Cooling the body down is thought to slow tissue damage
Scientists have developed new ways to cool heart attack and stroke victims' brains to protect them from brain damage.
UK doctors believe that cooling could save lives by slowing the release of harmful chemicals from nerve cells, and many hospitals have adopted the idea.
Among the inventions, reported in New Scientist magazine, is a cap that blows cold air across the scalp.
Other innovations include a chilling nasal spray and an icy lung injection.
Many intensive care units across the UK now use cooling techniques to help heart attack patients after two major research studies showed significant benefits.
This "therapeutic hypothermia" is normally induced using cooled pads, ice packs or even injecting chilled saline liquid into the blood stream.
However, researchers are hunting for ways to achieve the necessary 4C drop more efficiently - or targeting only the brain itself. You have to treat 30 patients with clot-busting drugs after a heart attack to save one life - with cooling it is more like six
The first of the new devices, developed at the University of Edinburgh, is a cooling helmet which works by passing cold air across the scalp, exploiting the dense network of blood vessels there.
Tests on volunteers, reported in The British Journal of Anaesthesia suggested that the hood was able to cool the brain by 1C per hour.
In the US, scientists are working on other quicker ways to achieve this, one by spraying a fine mist of droplets deep into the nasal cavity.
The liquid used, perfluorocarbon, evaporates rapidly, taking heat away from the area, and cooling the brain as a result - by up to 2.4C per hour.
A trial in pigs suggested this might not just reduce the chance of brain damage, but also improve the chances of successful resuscitation.
Cooling has the potential to be a major lifesaver: "You have to treat 30 patients with clot-busting drugs after a heart attack to save one life - with cooling it is more like six."
Sounds like a good idea to me; brain damage is often made worse by brain swelling and being trapped inside the cranium.
The999Kid
PostPosted: 21:40 - 04 Feb 2010    Post subject: Reply with quote
ulthar wrote:
My understanding is that the brain is starved of oxygen and the temperature rises causing the swelling. The ThermaHelm brings down the temperature to a safe level through cooling and reduces swelling thus reducing the risk of oxygen starvation.
Surely the company behind this think that temperature does matter in relation to head injuries hence the development of the ThermaHelm.
Others think cooling the brain after a head inujury works too:
https://www.hta.ac.uk/news/newsitem040609.shtml
https://www.babychums.com/2009/10/infant-brain-damage-reduced-by-cooling-treatment-finds-uk-study/
Your information must be out of date. Karma
I have bolded the erroneous section of your post, unfortunately due to the nature of the skull, this is the only body part that will not undergo a decrease in internal pressure through cooling.
As you cool the external surface of the patients head the skin contracts as a response to the cold, but so does the skull, but to less of an extent, so whatever pressure is decreased by tissue contraction, is lost through the contraction of the skull..
However! There is much to be gained in the fact that cooling a tissue reduces cell decay and death, retards blood flow and can prolong the life of tissues in oxygen poor environments.
My argument was not against the effect of the helmet (or at least i hope i wrote it to that effect) but that the cooling effect would reduce the intracranial pressure.
The last post was made 16 years, 261 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 80.86 Kb
