| Peat |
 Peat Renault 5 Driver
 Posted: 09:42 - 28 Jun 2004 Post subject: Rear brake / swing arm / suzuki gn125 |
So on the way to work this morning, braking lightly on the approach to a junction i felt a hard knock coming through the back brake pedal, at which point the brake locked (as in it wouldn't move, not as in the back brake locked on and I couldn't move) I continued slowly to work using only the front brake. When I got to work unpon examining the rear wheel found that the rear brake control rod had sheered off and wrapped itself roung the rear hub (it's not interfering with anything, just neatly wrapped round the outside of the hub out of harm's way) I also noticed that a bolt has sheared off from the *swing arm* whatever it is, fairly sturdy bar connecting frame to outside of the hub???
Question, is this safe to do any slow miles on or should I get a repair guy to it?
Any ideas what could have caused it?
How much to fix???
Sorry about the sh!t pics... camera phone and rear lighting  ____________________ Peat
"Life is something that happens when you can't get to sleep." |
| Frost |
 Frost World Chat Champion
 Posted: 11:21 - 28 Jun 2004 Post subject: |
The swingarm is the bit which is attached to the spindle of the rear wheel. if that is snapped then dont ride it, dont sit on it!
if you have just gotyou words in a muddle and you just mean he bit pictured, then so long as its not going to get caught in your wheel or generate alot of heat then yes you can ride that home.
Looks to me like bolt has come out of the arm that hold the drum in place (stops it spinning around)
how the spring off the rod attached to your back brake and got wrapped around the drum i shall never know!
just a case of putting in and tightening up a few bolt, should be simple and cheap to fix |
| Frost |
| Peat |
| Guest |
 Guest Brolly Dolly
| VFR400UK |
 VFR400UK Scooby Slapper
| Peat |
 Posted: 01:09 - 02 Jul 2004 Post subject: cheers |
cheers guys, will drop it off for fixing over the weekend... this always happens to me, I'm about to sell something big (e.g. my previous mini and then my spitfire) and something major goes wrong and costs me loads (okay, so a few bolts and a rod straightening ain't going to break the bank but you knowwhat i mean) ____________________ Peat
The last post was made 21 years, 174 days ago. Instead of replying here, would creating a new thread be more useful? |
