| Cigaro |
 Cigaro World Chat Champion
| taz4626 |
 taz4626 Renault 5 Driver
| Cigaro |
| rob_scott92 |
 rob_scott92 Could Be A Chat Bot
 Posted: 17:38 - 17 Jan 2010 Post subject: |
Does the CDI use the battery to work? If not, it could be the same as the problem i had with the Gs 125, Problem with the field coils. But if it was running and now its not, its likely you may have disconnected something.
Hope this helps in some kind of way haha
Rob  |
| 27cows |
 27cows World Chat Champion
| Robby |
 Robby Dirty Old Man
| Cigaro |
| Robby |
 Robby Dirty Old Man
 Posted: 11:54 - 19 Jan 2010 Post subject: |
Your local bike shop will have a coil tester, and they'll probably test your coil for a tenner or less.
For an easy test of it, I understand that they charge while a current is applied to the coil and discharge (causing the spark) when the charge is removed. Try running the coil on a direct feed from the battery, holding the plug close to the head, then pulling the positive feed and seeing what happens. Hopefully it'll create a single spark.
Realistically it probably won't and you've need 4 hands.
Bits to check from what I have seen of my CB250RS wiring loom (shudder).
Look for a concealed immobiliser. Someone had put a little switch on mine by the carb to cut the ignition circuit.
Look for an inline fuse somewhere.
Look for any dodgy wiring repairs in the past, like corroded bullet connectors.
Check the coil, pickup coils, alternator, CDI using the tests in the haynes manual. There are assorted tests to check the resistance against them.
The fun bit. Check wires for continuity with a multimeter.
Does everything else (lights, horn etc) work? |
The last post was made 16 years, 255 days ago. Instead of replying here, would creating a new thread be more useful? |
