| J D |
 J D World Chat Champion
| boundy |
 boundy Nearly there...
| J D |
 Posted: 17:59 - 18 Jan 2010 Post subject: |
I dunno i seem to remember G mentioning they were fairly reliable bikes, not sure what model Husky it was though. ____________________ m0l0t0v wrote: Chris, just so you know, JD is a nutter
| Pie-Roe |
 Pie-Roe World Chat Champion
 Posted: 18:11 - 18 Jan 2010 Post subject: |
It is this model that G recomends.
One of the best handling bikes I've ever owned or ridden.
Mine did blow its head gasket about 3k miles after I got it, which led me to have immense problems. You have to split the cam chain to get the barrel off, and some fuckwit had rounded off the sprocket bolts.
On the plus side, 95mph with the gearing I had, and that would lift the front off the power in first and second.
Brakes were good, I was using dunlop sportmaxs and it seemed to work well. Every day use, personally I changed the oil every 1k miles and the filter 2k miles, which put it to 15 quid a month for me. The valves are very easy to check. All in all a good bike, although the tank on mine was pretty small, you can get a bigger one.
People that automatically suggest an xr or xt really annoy me . Sure they might be a fraction more reliable, but they are the same age or older, weigh a lot more, aren't as comfy and have less power.
Pyro ____________________ Previous: GSF600, FZR600 x2, ZXR750, XT600 Tenere, CB125, CZ125, ETZ 250, ER5, CCM R30, DRZ400, RF600x4, RF900x2, GS500, VTR1000F, 640 SMC, CB250 NIGHTHAWK, GT550x3, GPX750 TE610, CB500, X11x2, SV650, ZING 125, TL1000R,CB250 Superdream, CBR1100XX |
| G |
 G The Voice of Reason
| tykey |
 tykey Scooby Slapper
| Itchy |
 Itchy Super Spammer
 Posted: 03:38 - 22 Jan 2010 Post subject: |
The TE610 is a good handling bike, on paper it is one of THE best bikes out there, weight, performance, gears, power etc in reality the reliability is highly suspect, take it this way if the TE610E is so good with G banging on about it regularly why doesn't he own one?.
One rider across the USA doth not a reliable bike make, same thing with the BMW X Challenge. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| G |
 Posted: 07:45 - 22 Jan 2010 Post subject: |
| Itchy wrote: | The TE610 is a good handling bike, on paper it is one of THE best bikes out there, weight, performance, gears, power etc in reality the reliability is highly suspect, take it this way if the TE610E is so good with G banging on about it regularly why doesn't he own one?. |
Because I couldn't find one second hand at the time - I did TRY and buy the only one I could find second hand in the UK, but it was written off a few days before I rung up - I did see if I could buy the salvage back, but he never got back to me .
As it was a case of buying new, I ended up with the KTM as I decided that it was a bit better in quite a few ways (including being compatible with bikes I already owned), apart from the gearbox. While the gearbox is a bit of an annoyance on it, I would be recommending them too if you could get them cheaper.
There's a decent few other people on advrider with them too - you'll note that 'the' TE610 that did the TAT was then sold to 'fishfood' who's gone on to do many months more in South America - but, indeed, one rider does not say much. I believe when recommending I generally have made it clear that it was the 2006+ FI models that I had 'researched' quite a bit and this was where my knowledge was.
The XChallenge uses the 'proven' F650 engine, though things like the air suspension are slightly more questionable. |
| J D |
| G |
 Posted: 09:14 - 26 Jan 2010 Post subject: |
| Pie-Roe |
 Posted: 10:34 - 26 Jan 2010 Post subject: |
is that the 644 engined one? Handling on mine was immense, but I found it hideously underpowered. Quite a few little things you can do to unlock a few more horses.
I have a full set of jets laying around somewhere from when I was playing with the fuelling, if I can find them your welcome to them for the price of postage.
Replace the side stand bolts as soon as you can, they are made of cheese and will snap at a horrible time.
| J D |
 Posted: 07:47 - 27 Jan 2010 Post subject: |
I take it you dont approve
Pyro its the 604 version, what was your mpg like? Gotta ride it back 200 miles  ____________________ m0l0t0v wrote: Chris, just so you know, JD is a nutter
| G |
 Posted: 09:10 - 27 Jan 2010 Post subject: |
They're supposed to be a decent chunk heavier than the TE etc - probably not a big issue for normal road use however.
Also, the rotax engine has 'questionable' reliability records . |
| Pie-Roe |
 Posted: 18:49 - 27 Jan 2010 Post subject: |
| jdloyalroyal wrote: |
Pyro its the 604 version, what was your mpg like? Gotta ride it back 200 miles  |
I was getting 80 miles to a tank, but I think the fuelling was off, and I was riding it relativly 'hard'
Good luck doing 200 miles in one stint, not something I personally would do.
| G |
 Posted: 19:18 - 27 Jan 2010 Post subject: |
I've got some sheep skin pads around if you'd like a bit more comfort .
Though done 200 miles on similar bikes and it's do-able but not great fun. |
| J D |
 Posted: 16:16 - 29 Jan 2010 Post subject: |
Well i made it back, love the bike although i might try swapping it for an old shape r6  ____________________ m0l0t0v wrote: Chris, just so you know, JD is a nutter
| J D |
 Posted: 19:06 - 30 Jan 2010 Post subject: |
Pyro when you mention the side stand does it just fall off or bend back so it wont hold the bike up, the latter happened to me today  ____________________ m0l0t0v wrote: Chris, just so you know, JD is a nutter
| Pie-Roe |
 Posted: 19:34 - 31 Jan 2010 Post subject: |
| jdloyalroyal wrote: | Pyro when you mention the side stand does it just fall off or bend back so it wont hold the bike up, the latter happened to me today  |
Mine started to lean excessivly over a period of 3 days, then snapped off at the bolts. They seem to vibrate out slightly, then bend. Replace with std bolts and it's fine
| boundy |
The last post was made 16 years, 234 days ago. Instead of replying here, would creating a new thread be more useful? |
