ns125f
adam coomber
PostPosted: 17:40 - 20 Jan 2010    Post subject: ns125f Reply with quote
hi to all !
I have a honda ns125f witch i have own for nearly two years now. I used it for a few weeks and the piston went . At the time i could not sorce new piston etc because of them being nicosil plated and was quite expensive to replate them ect.
in the end i managed to find a athena 190 big bore kit for it so i brought one and fitted it, bike was great for hum 6 weeks or so then bang went again so i brought anotherone lol.. again was all good for a while and guess what bang it goes again.
What i am in the middle of doing atm is - ive managed to sorce a standard barrel that has been reconed and had steel linner put in it and what i want to no is how many miles should i run it in for at what sort of revs and will it be more reliable cause spent best part of a grand on it now and its starting to piss me off because off the fact its not lasting very long..
Sorry for the long post im new to this and i think its a very good forum so very usefull people on here and i hope one off them can help me.
Cheers people !
lllN30lll
PostPosted: 18:31 - 20 Jan 2010    Post subject: Reply with quote
how come your asking how to run an engine in now that you've buggered 2 big bore kits up?
how did you run the first kits in?
Turbo R1
CRF450R
adam coomber
PostPosted: 19:07 - 20 Jan 2010    Post subject: Reply with quote
BLUEX5 wrote:
Bikes don't go bang for no reason. You need to find out why it blew up before you even consider putting yet another new top end on it.
can you give me some ideas on what would cause it ?
adam coomber
PostPosted: 19:11 - 20 Jan 2010    Post subject: Reply with quote
I ran it for few hundred miles at about 50mph but think little end bearing was causing it so replacing that aswell now .....
lllN30lll
PostPosted: 19:17 - 20 Jan 2010    Post subject: Reply with quote
it's not the speed that's important, it's the RPM when running in.
Turbo R1
CRF450R
PostPosted: 19:18 - 20 Jan 2010    Post subject: Reply with quote
It would help if you gave us your definition of bang.
adam coomber
PostPosted: 19:20 - 20 Jan 2010    Post subject: Reply with quote
it's not the speed that's important, it's the RPM when running in.[/quote]
ok what sort of rpm should i run at then ?...
adam coomber
PostPosted: 19:23 - 20 Jan 2010    Post subject: Reply with quote
the first time it went it shattered the front of the piston , and the second time the rings got stuck in and and worn down the sides of piston .....
tvr321
PostPosted: 20:30 - 20 Jan 2010    Post subject: Reply with quote
It needs rejetting. You are most definitely running very lean, which means it will overheat quicker, the piston expands and... ouch.
PostPosted: 20:36 - 20 Jan 2010    Post subject: Reply with quote
Rule of thumb use about half the red lines worth of rpm (ie, red line at 10k, only rev to 5k).
Did you check the jetting when you fitted the big bore kit?
adam coomber
PostPosted: 22:16 - 20 Jan 2010    Post subject: Reply with quote
ok thanks keith ..
all jets are still standard jets so could explain it as with the big bore kit i should of changed the jets i guess. and thank you all for your good and knollagable advice cause am due to receive new parts tomorrow and dont want to be going through it all again..
also could anyone tell me what the carb settings should be so that i can get the mixture right for it please?
thanks ...
adam coomber
PostPosted: 22:48 - 20 Jan 2010    Post subject: Reply with quote
forgive me for being thick but what the fock do you mean by plug chop ? lol
PostPosted: 22:59 - 20 Jan 2010    Post subject: Reply with quote
Plug chop. Basically find a steep hill. Accelerate up it holding it on full throttle / high revs. Without backing off first pull the clutch and hit the kill switch at the same time. Coast to a halt and pull out the plug. The colour of the plug will give a good idea of how rich it is running. Only really works for the main jet.
adam coomber
PostPosted: 23:06 - 20 Jan 2010    Post subject: Reply with quote
cool thanks keith might try it one day lol this is what i like about this site you learn something new everyday and you get good freindly avice ..
cheers
The last post was made 16 years, 242 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 91.32 Kb
