New exhaust, what would you expect to change jet wise?
Blue_SV650S
PostPosted: 18:44 - 20 Jan 2010    Post subject: New exhaust, what would you expect to change jet wise? Reply with quote
I have put a new can on the WR250F, as it comes with a long header, it is more like a 3/4 system. The old one was a different shape/length and had a pea shooter end.
Now I know this is a bit of a piece of string question, but what would you expect to change jet wise?
I relaise the only proper way to do this is to stick it on a dyno, but I am happy to play ... just want to keep it 'safe' for the little motor ...
anyhoo, it had a 170main, I have put a 175 in there (fairly arbitrary size swap) ... how much would you expect to have to upjet for a new zorst??
My main cocerin is that if I whack the throttle wide from low revvs, the bike bogs down - presumed it was lean .. but wondering if rich as when I put the choke on it doesn't prevent it and rolling off the throttle it then picks up??
To be honest I am not sure the jetting has ever been right ... going to have a gander at the manual to see what stock it ....
I guess this post is really just airing my thoughts ...
At the moment, the bike has a massive flat spot low 1/3 revs - it then takesoff .... as I am whacking the throttle wide and it is NOT a CV carb (I don't think) ... I am only considering the main jet at the mo ...
I might just put the standard one back on Confused
PostPosted: 20:31 - 20 Jan 2010    Post subject: Reply with quote
Presume it is a CV carb?
Either way if it is bogging down at half throttle, etc, from being lean then lift the needle a touch.
Blue_SV650S
PostPosted: 20:38 - 20 Jan 2010    Post subject: Reply with quote
No it is NOT a CV carb and it is at WOT therefore the needle has nothing (v-little) to do with the jetting at that point.
It has a funky slider thingy though ... its a bit like this ...
https://www.tokyomods.com/images/carburetion/FCR-MX.gif
PostPosted: 20:50 - 20 Jan 2010    Post subject: Reply with quote
Well, you shouldn't be using full throttle at low revs Wink . Full throttle at low revs and the carb is going to barely work at all.
I presume it has an accelerator pump setup. In which case see if you can adjust the stroke of that.
Blue_SV650S
PostPosted: 22:12 - 20 Jan 2010    Post subject: Reply with quote
This got me thinking ... I bet this is not working properly ... doing some google-reading looks like there is an o-ring mod you can do ... but it also said somewhere about them being sensitive to water and muck ... I am perpetually draining off my float bowl to get rid of water ... so I think I might have adrop or two in the acellerator diaphram bit ... the jetting might be fine ...
At the end of the day, are 4-strokes really that critical on jetting? As I said, it just has the can on and I have gone up form a 170 to a 175 just in case it leaned it out a bit ... am I likely to need to go more than that??? How much is a 4-stroke normally up-jetted for a can?
EDIT: FYI I just found this https://www.thumperfaq.com/ap.htm and having a read!! Thumbs Up
PostPosted: 23:07 - 20 Jan 2010    Post subject: Reply with quote
Main jet should only really be relevant on full throttle which you should only be using at high revs. Most of the time it will be the needle that is important.
Jetting is important on a 4 stroke. Probably not as prone to sudden seizure from running lean as a 2 stroke. Still possible to burn a hole in a piston from running lean. And quite easy to lose a load of power from getting the jetting wrong.
Blue_SV650S
PostPosted: 23:13 - 20 Jan 2010    Post subject: Reply with quote
It had notably* more power with the 170 and new pipe than the 175, so I am hoping that the 175 is a little over rich ... or at least further on the safe side of optimum ...
The more I look at this the more I think the Accelerator pump/Leak jet that either needs clearing out (water) or setting up .... Thumbs Up
*possibly part placebo
Blue_SV650S
PostPosted: 18:56 - 23 Jan 2010    Post subject: Reply with quote
Ok, ... tried playing with the accelerator pump settings, tried the O-ring mod ... did make differences, but not really 100% happy with the results ...
So, had the carb fully apart inc the accelerator pump - no muck or water in there as it turns out.
Adjusted the needle height raiseing the needle up 1 clip (moved physical clip down a position - raising needle)).
Still wasn't happy with results ..
The bike was loud, it lacked low down grunt/had big flatspot and then went totally larey when it came on cam/pipe ...
I mostly wanted a new pipe to try and get some more low down grunt, perhaps to liberate a bit more top at the same time (why not) and to make the bike look less ghey .. it didn't really achieve any of these .. so I have taken it back off again and thrown it to one side in disgust! Embarassed
Attached is the standard can ghey monstrosity I was trying to get rid of ... with the little bendy over bit at the back, it is V-Ghey Sad
https://www.bikechatforums.com/files/wr_original_can.jpg
PostPosted: 00:40 - 24 Jan 2010    Post subject: Reply with quote
When I fitted a stage 1 dynojet kit to my bike to suit the louder exhaust and more free flowing air filter there was a realtively small increase in jet size.
The throttle needle profile was radically different though.
If you can afford to splurge on an exhaust because you don't like the look of the old one. You can afford a stage 1 kit.
They cost £75, which is a lot. But they've done the R&D to answer the question that has not been answered here. Just keep telling yourself that's what you're paying for, not a plastic box with a jet, a throttle needle and two washers in it.
PostPosted: 02:21 - 24 Jan 2010    Post subject: Reply with quote
Isn't the bent bit so that water is less likely to fill your exhaust system up if it got submerged?
Blue_SV650S
PostPosted: 15:19 - 24 Jan 2010    Post subject: Reply with quote
At £75 a kit I have always thought people are better off taking it down the dyno and getting it done properly!! Wink
er ... I suspect it is to do with sound emissions ... i.e. it directs the exhaust gas and therefore the sound towards the ground - not rearwards where the sound meter is!! Wink
Ariel Badger
PostPosted: 15:35 - 24 Jan 2010    Post subject: Reply with quote
Blasting your exhaust at the rear tyre helps to keep the tread clear of mud.
PostPosted: 18:15 - 24 Jan 2010    Post subject: Reply with quote
If you take it to a dyno place they are still going to need to alternative needles, which will probably come from a dynojet kit.
Blue_SV650S
PostPosted: 18:43 - 24 Jan 2010    Post subject: Reply with quote
Shame it doesn't point at the rear tyre then isn't it!! Very Happy
If it needs a needle ... Wink ... presuming they pull a needle out of a box of needles and a jets out of boxes of jets, I can't see you would need more than say £25-30 in bits ... you then have £40-45 in dyno runtime and exhaust analysis ...
A dynojet kit is a generic fit isn't it?? ... therefore by virtue, there is no way it can 100% suit ALL combinations of airbox and exhaust combos 100% is there ...
At least after a dyno run you have it spot on for YOUR bike/setup Thumbs Up
This is all moot anyway as I am too tight/lazy to get it to a dyno Embarassed
PostPosted: 19:00 - 24 Jan 2010    Post subject: Reply with quote
The needle is probably picked from a box marked "Dynojet" Wink .
The idea of the dynojet kit needles is that they shaped for what is expected in the engine in the state of tune that it is aimed at (hence various different stages of kit), with needles having grooves so that they can be moved (unlike most standard needles).
Sure if you take it to a dyno shop they might have a box of hundreds of different needles for your carb (but unlikely), but by the time you have paid them to change the needle half a dozen times until they get one that works well (and probably similar in profile to the dynojet one) it has probably cost even more.
PostPosted: 23:43 - 24 Jan 2010    Post subject: Reply with quote
The advice i got from my local dyno place was to fit the stage 1 kit and if I wasn't happy, pop it down for fine tuning.
He said that the first thing they'd do is fit the needles and springs from one anyway then work from there. On my bike that's a good half hours labour saved straight away, as well as getting the best online price for the jet kit.
The last post was made 16 years, 226 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 101.79 Kb
