Piston Rings
delvey91
PostPosted: 19:39 - 20 Jan 2010    Post subject: Piston Rings Reply with quote
Hi all,
Im rebuilding a DT 125 engine at the moment. The problem is ive got a new piston and i dont seem to be able to get the top ring to sit properly, Bottom one went in fine but the top dosent want to go in! Tried them the other way round but no difference! There both located correctly in relation to the little pins.
Also the kit also came with a small springy ring whats this for??
2016 Honda Africa Twin
2006 KTM 200 EXC
MaybeGuy
PostPosted: 19:45 - 20 Jan 2010    Post subject: Reply with quote
Did the rings come with the piston?
delvey91
PostPosted: 19:46 - 20 Jan 2010    Post subject: Reply with quote
Yep they came with the piston, its a genuine yamaha kit
2006 KTM 200 EXC
MaybeGuy
PostPosted: 19:51 - 20 Jan 2010    Post subject: Reply with quote
definately a dt piston? Small springy one sounds like an oil scraper ring found on 4 strokes.
Any pics?
Blue_SV650S
PostPosted: 20:02 - 20 Jan 2010    Post subject: Re: Piston Rings Reply with quote
delvey91 wrote:
Hi all,
You will find that one (or both) of the rings is slightly tapered. If one don't seem to fit, try flipping it upside down and then in each land do this until you have found the right home and orientation for both!! Thumbs Up
btw pics of the 'small springy ring' plz, but it is probably supposed to go under the lower of the two rings ..
delvey91
PostPosted: 20:19 - 20 Jan 2010    Post subject: Reply with quote
Hmm tried fliping them and got the top to squeeze in but its deffo to stiff, the bottom one is ideal i think?
Pics:
https://i280.photobucket.com/albums/kk193/delvey91/DSC01823.jpg
Springy one:
https://i280.photobucket.com/albums/kk193/delvey91/DSC01824.jpg
2006 KTM 200 EXC
Blue_SV650S
PostPosted: 20:33 - 20 Jan 2010    Post subject: Reply with quote
Pics:
Try all combinations top and bottom, and flipped both ways (you can see the taper, but it does take a keen eye, so best just to experiment). Also one ring can be thicker than the other.
As for the multi sided ring, yes that is supposed to go under one of the other rings (seen them in kits before) I think it is supposed to be under the bottom ring.
Although I have seen them before, I have never had to use one before, so best wait for someone that has to come along and say for sure which ring it sits under (to be honest, you can probably get away without using it at all?!).
Quote Me Happy
PostPosted: 20:42 - 20 Jan 2010    Post subject: Reply with quote
I had the exact same problem with a diddy PW50 piston. Never did get the top piston to seat properly so ended up using the original top ring. Far from ideal but it was an old bike for kids so didn't really care too much.
I did measure both sets of new rings with some (crap) vernier calipers and they appeared to be the same size.
The very thin ring sits behind one of the other rings, probably the bottom ring.
PostPosted: 22:08 - 20 Jan 2010    Post subject: Reply with quote
The expander ring sits underneath the bottom ring, but it's up to you whether you use it or not. Some people leave them out, some fit them. Have a Google Thumbs Up
EDIT: I just had a Google and found nothing. I read it in A Graham Bell's 2 stroke tuning book though so if anyone has that they could quote from it.
oldbiker
PostPosted: 19:29 - 21 Jan 2010    Post subject: Reply with quote
Top ring is tapered about 7 degrees I think, but the taper is only on the top face of the ring.
The top ring is usually quite stiff.
Also the top of the piston is machined a little narrower than the rest of the piston, so the ring being too big may just be an illusion.
As others have said the expander ring goes with the bottom ring.
It`s all powerfull white mans magic
https://i897.photobucket.com/albums/ac178/tzrsteve/album%201/035.jpg
delvey91
PostPosted: 20:10 - 21 Jan 2010    Post subject: Reply with quote
Cheers for the help guys, got it all sorted today. Yeh after a bit more swapping and turning it fitted like a glove in there! And it started first kick! Im well chuffed first rebuild ive done and it works Surprised
2006 KTM 200 EXC
The last post was made 16 years, 233 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 69.36 Kb
