Brake Caliper Bolts Seized
Thom
PostPosted: 10:59 - 22 Jan 2010    Post subject: Brake Caliper Bolts Seized Reply with quote
Sorry lads, i admit this is not bike related but this was the best place i have access to!
I have a Ford Fiesta from '98 and the front right brake is binding quite severely. i need to remove and strip the caliper however the two bolts holding the caliper on are both seized and VERY rounded.
The bolts are fairly inaccessible, i cant grind the heads and drill them out due to this, a file is far too slow and i have no further ideas.
Any suggestions other than let a mechanic do it for me?
Quote Me Happy
PostPosted: 11:13 - 22 Jan 2010    Post subject: Reply with quote
Can you get an impact driver in there?
Thom
PostPosted: 11:16 - 22 Jan 2010    Post subject: Reply with quote
unfortunately no, even on full lock i gain little extar in the way of space. i have a nasty feeling to get access it's going to involve removing various suspension components Crying or Very sad
DrDonnyBrago
Hammer on a slightly smaller socket (lifetime guarantee helps!), try an imperial socket onto a metric bolt i.e. 9/16" onto a 15mm bolt as the 14mm will be harder to hammer on.
alternatively file two of the sides down and slip a spanner (maybe an adjustable one) over it.
failing that then a blow torch, penetrating fluid (not WD40!!!) and mole grips works wonders!
DrDonnyBrago
PostPosted: 11:18 - 22 Jan 2010    Post subject: Reply with quote
sorry I assumed it was a hex head bolt!
Thom
PostPosted: 11:23 - 22 Jan 2010    Post subject: Reply with quote
it is/was previously however they might as well be round, i assume theyre made of steel but theyre so soft its unreal.
PostPosted: 11:32 - 22 Jan 2010    Post subject: Reply with quote
I assume these are the large bolts holding the complete caliper to the hub (rather than small ones holding the sliding part of the caliper onto the carrier).
Can you remove the disk and get at the other end of the bolts? Access to a welder to weld a bolt onto the rounded heads (both to provide something to grip and also to get a load of heat in to undo them)?
Or something like these:-
https://www.machinemart.co.uk/shop/product/details/5-piece-bolt-grip-set/path/socket-sets-sockets-tool-sets/brand/irwin
Raffles
PostPosted: 11:47 - 22 Jan 2010    Post subject: Reply with quote
Are you sure that these ''hexagon head bolts that might as well be round'' aren't actually Allen bolts? I've owned Ford Escorts (which share many common parts with the Fiesta) and the bolts that you may be referring to are actually 7mm Allen bolts. I'd suggest cleaning all the accumulated road dirt away and taking a closer look.
Thom
PostPosted: 11:57 - 22 Jan 2010    Post subject: Reply with quote
The bolts that mount the calliper to... their mountain point are 1/2" 6 point bolts. Certainly not allen bolts.
I cant remove the disc without removing the caliper, this may be possible if the piston wasnt seized and i could push the piston back into the caliper hwoever this isnt the case.
The last post was made 16 years, 230 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 61.17 Kb
