Fixing holes in exhaust
map
Mr Calendar
PostPosted: 13:02 - 24 Jun 2004    Post subject: Fixing holes in exhaust Reply with quote
Question I've got two holes in a CG125 exhaust. I've been told that a self-taping screw in each should solve the problem.
Problem is I've never tried this, do I need any sealer or just screws?
How long will this fix last?
If I get chance I plan to take off the exhaust, treat the rust and coat it in black exhaust paint. So is there any other fixes I should try?
Any advice appreciated. MAP
mr jamez
PostPosted: 13:19 - 24 Jun 2004    Post subject: Reply with quote
Well if you are going to bodge it with a self tapping screw I would cover it in gun gum, and then when it is in the exhaust shove a load more over it! It probably will blow out eventualy, so you will have to keep applying it now and again.
Jammy-G This post is not being displayed because the poster is banned. Unhide this post / all posts.
map
Mr Calendar
PostPosted: 09:35 - 25 Jun 2004    Post subject: Reply with quote
Thanks for the advice on JBWeld Thumbs Up
Will try and get some, bound to look better as I intend to paint the exhaust anyhow.
map
Mr Calendar
PostPosted: 15:35 - 28 Jun 2004    Post subject: Reply with quote
Thanks again for the info. Exhaust will probably end up whatever colour I can get. Previous owner tried black but it's flaked off so looks naff. May try again black or see about a brushed aluminium look. Let you know how I get on, been too busy this weekend to get the exhaust off. Rolling Eyes
mrchips
PostPosted: 22:18 - 28 Jun 2004    Post subject: Reply with quote
Just weld it.
mr.z
PostPosted: 08:36 - 29 Jun 2004    Post subject: Reply with quote
Where exactly are these holes?
i wouldn't worry too much, if a couple of screws will cover it then there not gonna be a big problem.
Also bear in mind you can get cg exhausts for not very much (probably how much it would cost you in welding) from a bike breakers if it came down to it.
ts50x0
PostPosted: 14:52 - 02 Jul 2004    Post subject: Reply with quote
whatever you do dont use exhaust tape from halfords. i put some on my bikes exhaust and the exhaust hole go bigger underneath the tape. so when i was ridin along it blew the tape apart and i found a hole 10 times as big as before. and it was insanly loud for my 10 mile ride home. i would also go down my local breakers yard and get a new one. search google for breakers yards in your area. that how i found mine and now im a regular. you wont regret it.
good luck Very Happy
The last post was made 21 years, 175 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 61.68 Kb
