GZ125 starts fine, cuts out
Zero
PostPosted: 12:01 - 23 Jan 2010    Post subject: GZ125 starts fine, cuts out Reply with quote
Hi BCF,
My Suzuki GZ125 is starting ok, but it cut out as I was coming into work this morning and took a while to get going again. As soon as I start to open the throttle up it just cuts out and dies. I'm sure there's probably a number of reasons for this but what should I be checking and looking at to fix it?
I know it's a bit cold in the mornings but it feels like it's down to something else, as it's been colder and not happened before.
Thanks in advance for any advice!
- Ad
smegballs
PostPosted: 14:40 - 23 Jan 2010    Post subject: Reply with quote
Blocked main circuit in the carb?
Your idle circuit may be fine (hence easy start up) but if there is crap blocking the main jet the engine will stall as soon as the throttle is opened.
Try opening the throittle really really slowly and see if that improves matters at all. My SR 125 used to cut out if the throttle was blipped when the engine was cold.
The Artist
PostPosted: 14:53 - 23 Jan 2010    Post subject: Reply with quote
My bike does this when the electrics get wet and I need to sort it. Im gonna wrap a plastic bag around the coil for now until it warms up a bit and I can do a proper strip down and sort everything.
Mr White
PostPosted: 15:30 - 23 Jan 2010    Post subject: Reply with quote
clean your carb, make sure you put everything the way it was Smile
Zero
PostPosted: 16:05 - 24 Jan 2010    Post subject: Reply with quote
Thanks I appreciate the help, I'll see what I can do.
Cheers,
- Ad
The last post was made 16 years, 226 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 41.95 Kb
