Compression disappeared while sat in lockup (350 bullet)
PostPosted: 23:31 - 24 Jan 2010    Post subject: Compression disappeared while sat in lockup (350 bullet) Reply with quote
Really odd. On my Royal Enfield 350 bullet (pre-unit, air cooled, OHV, 350cc single).
I last rode it at the beginning of December. Rode it into the lockup, squirted liberally with corrosion inhibitor and shut the door.
Hauled it out today to find it has no compression at all. Kick it over and the engine just spins. Now this is a motor that would normally bump over compression without the decompressor only if I were to put my full weight on it and bounce.
I suspected the decompressor at first but having stripped that (and dropped the decompressor valve into the cylinder then retrieved it again with a magnetised allen key) I can pretty confidently say it's not that.
The sparkplug is in properly too.
This leads me to conclude the exhaust valve must be stuck open. Any ideas how or why that would happen to a bike that was running fine when put away and has been sitting in a dry lockup for 6 weeks?
Obviously I'll know more when I get the rocker covers and (if necessary) head off it but I can't do anything with it until Friday when I'm off work. Thought I'd get planning now.
Alexio
PostPosted: 01:09 - 25 Jan 2010    Post subject: Reply with quote
I guess your valve clearances for what ever reason could now be very far out? All I know is that when an OHV engine is turning over is puts oil up to the top of the engine to lubricate the push rod and valve stuff right? So while your engine was sitting, there was no oil up there. While there was no oil "protecting" your valves anything from minor corrosion to weird expansion or cohesion of parts could happen.
As you say though, you'll know once you have a look. I really don't know that much about diagnosing engine problems, I just really enjoy speculating (and learning!) Thumbs Up
How many miles has the bike done any way? How old is the oil? (just curious)
PostPosted: 01:27 - 25 Jan 2010    Post subject: Reply with quote
It's only been sitting two months and there will still be a smearing of oil over everything.
PostPosted: 02:06 - 25 Jan 2010    Post subject: Reply with quote
It's done just over 3,000 miles and the oil was changed about 250 miles ago.
hmmmnz
PostPosted: 04:38 - 25 Jan 2010    Post subject: Reply with quote
maybee the valve has wedged itself against the guide,
although it doesnt seem very plausible,
maybe the collet has broken and the spring has come loose
allowing the valve to stay open....
bugger if i could even guess
the humans are dead
I kick arse for the lord
PostPosted: 09:23 - 25 Jan 2010    Post subject: Reply with quote
From Pete Snidal's manual :-
Oil leakdown can occur if the machine is left for longer periods between use. This is when the oil which normally sits in the piston rings drains down into the sump, leaving the rings dry. Since oil is necessary to proper ring sealing, the compression goes away. This may be remedied by removing the spark plug, squirting a few squirts of oil from a squirt oil can into the cylinder, and spinning the engine over for half a dozen strokes of the kickstarter, then replcing the plug and trying to start in the normal way.
Will be worth trying before taking the head apart Smile
STONEY!
PostPosted: 15:04 - 25 Jan 2010    Post subject: Reply with quote
the shaggy da has got it in one (well hopefully!) very common with cb250rs singles
Alexio
PostPosted: 15:44 - 25 Jan 2010    Post subject: Reply with quote
If that turns out to be the diagnosis then at least I know that my thinking wasn't too far off of the mark. We'll be curious to find out the problem and hopefully won't have to wait all the way until Friday to find out!
That makes sense actually because don't you put a bit of oil down the spark plug hole to test if it increases compression if you are testing your piston rings anyway?
PostPosted: 16:31 - 25 Jan 2010    Post subject: Reply with quote
Yes, you do.
PostPosted: 16:37 - 25 Jan 2010    Post subject: Reply with quote
I always leave mine at TDC on the compression stroke (even overnight) This removes all strain from the valve gear and ensures the valves are closed which as a welcome bonus will prevent moisture entering the cylinder. Ths really is a must when storing this particular engine for any length of time because it will also prevent wet sumping.
On the assuption that it is a valve problem, knowing how slack the indian tollerances are, I would be very surprised if the valve had got itself stuck in the guide.
A valve/guide problem, which is easy enough to diagnose (the pushrod will remain tight no matter what position the crank is in) can often be solved with a rap on the valve tip to loosen it off.
I would guess either a tight rocker or a dropped valve seat is the culprit.
Frost
PostPosted: 17:10 - 25 Jan 2010    Post subject: Reply with quote
I was going to say oil until someone beat me too it Laughing
You could try a squirt of 2 stroke oil into the cylinder and see if that helps make a seal and gives a bit of compression. Worst case scenario, it'll smell nice Laughing
PostPosted: 18:14 - 25 Jan 2010    Post subject: Reply with quote
Well. It starts and idles now after bunging some oil down there by the light of my car headlights after work (blows perfect smoke rings out of the exhaust too).
There is still remarkably little compression at the kick start though. Maybe it'll sort itself out after its wee run. Failing that, I'll have a look at the valvegear on friday.
I'd have tried a test run but I also stripped the thread out of one of the front axle nuts at the weekend. Well, it more stripped itself to be honest, I only had 2 fingers on the spanner at the time and it must be an M18 thread at a minimum. Seriously ropy machining. Need to replace that before I can ride it.
I usually stop it using the decompressor but release it before the engine has fully stopped rotating. It ought to come to rest at TDC on the compression stroke every time.
mr.kris
PostPosted: 19:51 - 25 Jan 2010    Post subject: Reply with quote
you planing on comeing to the fezze up? this year sir? alittle off subject i know
TS50X---CM125---MZ150---Z250---RS125---ZXR250---BANDIT600---TRX850---TL1000S---CBF600---ZX6R---BANDIT1200S---CG125---VFR800---CBR1000F---CG125---CG125---CB900F---CB900F---CG125---TUONO1000R---KLR600---GSX1300R HAYABUSA---VFR400NC30---BANDIT1200---CG125
HAYABUSA now in use!
PostPosted: 00:37 - 26 Jan 2010    Post subject: Reply with quote
Depends when it is and if I'm off.
I'll PM you my email addy.
The last post was made 16 years, 232 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 87.09 Kb
