cg engine problem
fezza612
PostPosted: 16:05 - 25 Jan 2010    Post subject: cg engine problem Reply with quote
Hi all,
I have a 2002 cg and the problem is when i accelerate through the gears it revs loud and looses power like the clutch has been pulled in.
This only happens low down in each gear and when the engine is warm it stops. it also stops when i ease off the throttle and then re-apply it again.
any ideas?
Previous: '02 Honda CG125, '03 yamaha enticer
Current: '98 Kawasaki GPZ500S
finpos
PostPosted: 16:28 - 25 Jan 2010    Post subject: Reply with quote
slIppIng clutch - adjust at the lever, If It's run out of adjustment then you'll need to adjust It at the engIne end. If It stIll slIps, then eIther the clutch Is knackered or the cable and actuator Is full of wInter grot and Is partIally seIzed.
F.
The last post was made 16 years, 227 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 30.91 Kb
