have a problem with me dtr 125. can anyone help
gordy1234
PostPosted: 17:55 - 29 Jan 2010    Post subject: have a problem with me dtr 125. can anyone help Reply with quote
Hi everyone. I am having some bother with my dtr. I got the bike a while ago but the engine had gone, i was on this site asking if a 05 barrel would fit a 92 model. (thanks for the help it does) I put it on and built the bike up. I got it started after a wee bit and now it starts fine even from cold. But the things is its seems to have no power high up the revs. 1st and 2nd gear are alot stronger then all the rest but they still dont feel right. you put the bike in 3rd and it doesnt pull and if you try using 4th 5th and 6 it does nothing really. Any ideas what the problem could be.
forgot to say the chain is at the shortest ajustment and even at that its solid before you sit on it. hope you guys can help. Thanks.
PostPosted: 18:21 - 29 Jan 2010    Post subject: Reply with quote
shouldnt be solid... should have an inch - inch 1/2 movement.
Whats your spark plug look like after a hard run? what colour is it, just pop it out and have a look?
gordy1234
PostPosted: 18:37 - 29 Jan 2010    Post subject: Reply with quote
[quote="padwaxk88"]shouldnt be solid... should have an inch - inch 1/2 movement.
Whats your spark plug look like after a hard run? what colour is it, just pop it out and have a look?[/quote
Hi there just run out and took it out there the now. it looks black and theres a wee bit of oil on the threads.
i need to get an extra wee bit of chain then. would that be doing anything bad to it??
PostPosted: 18:53 - 29 Jan 2010    Post subject: Reply with quote
Probably giving the chain a hard time, which could give the engine and sprockets a hard time too..
The plug being like that could be running quite rich.. i'd wait for the 2 stroke geniuses to post, but i'd say mixture setting?
reggie
PostPosted: 18:56 - 29 Jan 2010    Post subject: Reply with quote
sounds rich how manny miles it done could need to clean the filter
gordy1234
PostPosted: 19:00 - 29 Jan 2010    Post subject: Reply with quote
i was thinking that myself. how could i sort that?? thanks for the help
gordy1234
PostPosted: 19:03 - 29 Jan 2010    Post subject: Reply with quote
Hi there. i was thinking it was running rich. em its done about20 mile or something since the rebuild. how could i sort that?? thanks for the help.
reggie
PostPosted: 19:17 - 29 Jan 2010    Post subject: Reply with quote
oh the person that had mine befor me never cleaned the air filter in 12000 miles chokeing the motor check the jets in the carb that none have come lose
gordy1234
PostPosted: 19:22 - 29 Jan 2010    Post subject: Reply with quote
Hi there when i done the rebuild i changed the filter anyway so i know its not that. how do i check the jets??
PostPosted: 19:27 - 29 Jan 2010    Post subject: Reply with quote
take the carb apart and just check the jet is still screwed in, had a mini moto that they jet fell out of, took ages to figure it out!
The chain, if its on the most slack setting i'd say either the sprockets arent standard or the chain isnt the correct length.
gordy1234
PostPosted: 19:48 - 29 Jan 2010    Post subject: Reply with quote
Hi there when i done the rebuild i changed the filter anyway so i know its not that. how do i check the jets??[/quote]
The chain, if its on the most slack setting i'd say either the sprockets arent standard or the chain isnt the correct length.[/quote]
i just phoned a friend there and he has a couple of links and the magic link too so that sound cover that. well wen i 1st started the bike its was not bolted down fully so was moving about a wee bit so i will have a look and see if its moved thanks for the help again.
PostPosted: 23:26 - 29 Jan 2010    Post subject: Reply with quote
im not sure you can add links to the chain...its usually a whole chain..
gordy1234
PostPosted: 01:51 - 30 Jan 2010    Post subject: Reply with quote
im not sure you can add links to the chain...its usually a whole chain..[/quote]
well al maybe give it a try if not al just get 1 they dont seem hard to come by. thanks
reggie
PostPosted: 02:45 - 30 Jan 2010    Post subject: Reply with quote
you can but you would have to have 2 joining links
when the shit hits the fan make sure its facing the other way.
gordy1234
PostPosted: 12:20 - 30 Jan 2010    Post subject: Reply with quote
true. well al see how it goes. goin to take it out today and see how its goin.
The last post was made 16 years, 267 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.64 - MySQL Queries: 15 - Page Size: 82.24 Kb
