arrow can, rejet???
jasepugh1984
PostPosted: 17:40 - 30 Jan 2010    Post subject: arrow can, rejet??? Reply with quote
just wondering i changed my end can on my rs125 2007 11kw for an arrow race can.my bike idles high when i rev it up for a few seconds,would i need to just change the main jet for a slightly bigger one?thanks,jason
Aprilia Rs125 2007 11kw (SOLD) - Honda CBR600RR 2008 (Current Summer Toy) - Honda Cb600 2000 (Current Work Commuter)
temeluchus
PostPosted: 17:52 - 30 Jan 2010    Post subject: Reply with quote
Generally when going to a less restricitve silencer (assuming youve gone from stock to loud/louder) then slightly richer jetting will be needed.
I'd also try giving your idle screw a 1/4-1/2 turn out to richen the idle mix a little.
For a silencer I wouldnt imagine needing more than 1 or 2 jet sizes bigger.
jasepugh1984
PostPosted: 18:08 - 30 Jan 2010    Post subject: Reply with quote
do you mean the mixture screw turn out? also when you say go up a a couple of sizes do you mean just main jet size?
temeluchus
PostPosted: 01:42 - 31 Jan 2010    Post subject: Reply with quote
yes the idle mixture screw. The screw only affects the idle mixture and doesnt help any further up the rev range.
The main jet yes.
jasepugh1984
PostPosted: 08:29 - 31 Jan 2010    Post subject: Reply with quote
my bike did originaly have an aprilia racing can it as standard and the arrow can is no louder,do you reckon i need to clean the carb all out before i just rejet,could it just be that the jets are bit blocked?or would it not run properly if this was the case.i have very limited mechanical ability you see.lol.
temeluchus
PostPosted: 16:49 - 31 Jan 2010    Post subject: Reply with quote
Ah! Possible there is crap in the carbs.
Remove the carby and give it a good clean with carb/choke cleaner spray, which you can get from any car parts place.
Refit, making sure all the clamps are secure and there are no holes in any of the rubber.
Also take the time to check your spark plug-may be worth replacing it if you've no idea when it was last replaced.
Also I'd check and replace your fuel filter if you have one fitted. Again you can buy one at halfords or any car place.
The last post was made 16 years, 75 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.37 - MySQL Queries: 13 - Page Size: 48.78 Kb
