| Conners |
 Conners L Plate Warrior
| Frost |
 Frost World Chat Champion
 Posted: 10:32 - 29 Jun 2004 Post subject: |
bump start it for now, then get a mechanic to look at it.. I'm near clueless with starters, but there must be something which engages and disengage it. this might be worn or simply broken.
Try taking the starter off, cleaning things up, lubricating and moving parts you can get at and put it back on. thats normally what i do when i'm clueless and it has a habbit of working  |
| Conners |
| Kickstart |
 Kickstart The Oracle
 Posted: 13:59 - 29 Jun 2004 Post subject: |
Not sure if it is the same between the Rotax 122 engined and 123 engined bikes.
On the older 123 engine the starter motor has a chuck piece that is on a very coarse screw thread. When the starter motor spins the chuck goes down the thread , outwards until the teeth on it engage with the teeth on the flywheel.
I would suspect that the chuck is sticking on the coarse thread. If this is the case then you would probably hear a fast turning quiet noise from the starter motor (might not hear it with a helmet on).
Take off the r/h cover which goes over the fly wheel. At about the 7 o'clock position on the flywheel there is a plastic cover. Take this off and you will see the starter motor chuck. Clean it out and lube it up.
| Conners |
| M1ke |
 M1ke Ped Boi
The last post was made 21 years, 204 days ago. Instead of replying here, would creating a new thread be more useful? |
