any H100 owners?
alex25
PostPosted: 11:55 - 02 Feb 2010    Post subject: any H100 owners? Reply with quote
hi there all,
i purchased a go-kart which had already been fitted with a H100 engine,what model i dont know..this engine turned out to be faulty.
anyway i had to find a replacement unit and its not running right at all.
i used the coil etc off engine 1, is there a difference with the electrics on these 2 engines ?
also how would i find out what model of h100 i have?
thank u
PostPosted: 12:05 - 02 Feb 2010    Post subject: Reply with quote
There are 3 versions of the H100 in the UK. The older A model, and the S and S2. The easy way to tell the engines apart is the cylinder heads. The S fins run straight forward backwards, while on the A they splay out at the front of the head.
The A and S generators appear to be different, but the coils appear to be the same.
Have a feeling the H100S had electronic ignition but not sure.
alex25
PostPosted: 12:13 - 02 Feb 2010    Post subject: Reply with quote
thanks for that
the kart could idle all day, till u go to drive it, its very slow. walking pace.
it does alot of popping and banging then cuts out
any ideas anyone ? thank u
27cows
PostPosted: 12:19 - 02 Feb 2010    Post subject: Reply with quote
H100s had one of the least reliable engines ever to emerge from the land of Nippon.
The H100A had CDI, the H100S inexplicably reverted to points, and the H100SII went back to CDI again. But the engines are extremely fragile. It was common for motors to be completely worn out by 15-20K. Would suggest trying to find something more robust for your kartie.
PostPosted: 12:20 - 02 Feb 2010    Post subject: Reply with quote
You can check the ignition timing (strobe light), but I would check the reed valves first.
PostPosted: 12:33 - 02 Feb 2010    Post subject: Reply with quote
I've seen convincing evidence to the contrary.
In my experience an H100 will take a phenomenal amount of abuse and still pull wheelies in first.
A mate of mine rode one from Edinburgh to Kirkwall and back, two-up and another mate used to regularly commute between Edinburgh and Nairn on his.
alex25
PostPosted: 12:41 - 02 Feb 2010    Post subject: Reply with quote
i was told the engine had low miles and was working etc, but thats what they all say eh,
i only replaced the engine with another h100 because the frame was made for the h100
with my wiring i have, coil and cdi box thats it
i have 2 photos of the kart to see anyone could spot what engine i have, that would be great, thanks
https://i34.photobucket.com/albums/d129/ll_sarah_ll/283807478.jpg
https://i34.photobucket.com/albums/d129/ll_sarah_ll/283807476.jpg
PostPosted: 13:00 - 02 Feb 2010    Post subject: Reply with quote
It is an H100S or S2 engine.
Put a filter on the carb. At the moment any grit will go in and cause damage, and the back tyre will probably fling grit straight at it. Will also run a bit lean due to the lack of filter which won't help things.
Tristan.
PostPosted: 13:53 - 02 Feb 2010    Post subject: Reply with quote
alex25 wrote:
thanks for that
Just a thought, whats the gearing like? Idling fine, then having no power at all and cutting out in gear could be caused by being very overgeared (unlikely with the tiny wheels, but it may of been overcompensated)
PostPosted: 14:19 - 02 Feb 2010    Post subject: Reply with quote
Good point.
That looks like a way larger than standard rear sprocket. Possibly 15 teeth between the "spokes" of the sprocket so a 60 tooth sprocket (standard is 35, front is 15 and you can't squeeze in anything bigger).
Stock gearing an H100 does about 20mph at 8500rpm in 1st gear. 60 tooth sprocket would knock that down to 11.5mph. An 11" tyre diameter would knock that down to 5.5mph.
Could well be running out of revs at little more than walking pace in 1st.
alex25
PostPosted: 14:24 - 02 Feb 2010    Post subject: Reply with quote
i has a filter there but it was off at that time, a non standard one, a k&n type.
i could drive it changing gears etc, but the pops and bangs caused it to die.
i believe the sprocket used is the H100
cheers
alex25
PostPosted: 14:29 - 02 Feb 2010    Post subject: Reply with quote
i will head out and count teeth on the sprocket and ill get a few more pictures etc
cheers
H100s use tiny rear sprockets (and still run out of revs). That looks way bigger than standard. Can you count the number of teeth?
Get hold of a strobe light and check the ignition timing. But also check the reed valves.
PostPosted: 15:07 - 02 Feb 2010    Post subject: Reply with quote
Indeed. Because if it's been popping and banging, if they weren't damaged before, they may well be now.
alex25
PostPosted: 17:27 - 02 Feb 2010    Post subject: Reply with quote
i think its up in high 50's , i take it that its wrong? its pretty hard to count when the chain is on lol
its been put on with a ton of weld also, lol
PostPosted: 17:32 - 02 Feb 2010    Post subject: Reply with quote
Way too large. Flat out an H100 does about 60mph. The wheels being smaller will lower the gearing by about 50% anyway, bringing the top speed down to about 30mph. Going from a 35 tooth (stock sprocket size) to one in the high 50s will almost halve that again.
Or put it another, the combination of larger sprocket an smaller wheel will land up making 5th gear lower geared than the stock 1st gear.
alex25
PostPosted: 18:06 - 02 Feb 2010    Post subject: Reply with quote
do u think its pretty pointless doing anything with it?
tbh it was only bought to cure boredum lol.
cheers
PostPosted: 18:17 - 02 Feb 2010    Post subject: Reply with quote
Keep playing (at least to stop the popping and banging), and put a sensible size rear sprocket on.
cb1rocket
PostPosted: 21:25 - 08 Feb 2010    Post subject: Reply with quote
It could well be the engine is over revving as the clutch is knackered? Just a thought
alex25
PostPosted: 17:15 - 12 Feb 2010    Post subject: Reply with quote
it's not over revving at all, its not revving nearly anywhere its supposed to.as
i had it going today, when i rev it in neutral its wanting to die all the time, i couldn't drive it as the ground wasnt flat enough.,but when it does do its popping and banging
would the piston rings cause this or is it bound to be something else
thanks
The last post was made 15 years, 358 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 109.02 Kb
