Suzuki RG125 Non Starter
DopeB
PostPosted: 09:34 - 30 Jun 2004    Post subject: Suzuki RG125 Non Starter Reply with quote
I've just bought an RG125 but it doesn't start. I've checked all the basic stuff and am still stuck.
The battery is charged and is turning the engine over.
The spark plug does spark and when I take it out after trying to start the bike, there is petrol on it.
I've played with the choke trying it on and off but it didn't make any difference.
The bike does sound like it wants to start but just won't.
Any ideas would be greatly appreciated.
Thanks Smile
Frost
PostPosted: 09:56 - 30 Jun 2004    Post subject: Reply with quote
Fuel
Spark
Compression
is all that is needed.
perhaps you have flooded it (i know nothing of 2 stokes btw Wink?
check the gap on the plug and clean all the oil and fuel off with a rag (especially where the spark goes). You may also want to check the fuel/air/oil mixture and make sure its not trying to start on oil and air.
Robby
Dirty Old Man
PostPosted: 11:52 - 30 Jun 2004    Post subject: Reply with quote
Things to check:
Is the carb secure in its rubber, or is there a possible air leak between carb and engine.
How many miles on the engine? If you've never had it running, it could just be knackered and due a rebuild. Check the compression and see what you get.
DopeB
PostPosted: 13:06 - 30 Jun 2004    Post subject: Reply with quote
The plug is nice and clean. It did have petrol on it after I'd tried to start it so I assume that it is getting juice into the barrel.
I haven't checked the card but I'll do that tonight.
I know the bike has been running recently (well a couple of months ago) but it did stop working and hasn't been touched since.
Someone also suggested I drain the tank and put fresh petrol in as it may have gone off.
I did want to get the bike MOTd next week so I can run it for the rest of summer (whatever is left of it anyway) but it may have to wait a bit longer Sad
Thanks anyway guys Smile
DopeB
PostPosted: 13:22 - 30 Jun 2004    Post subject: Reply with quote
I've just spoken to a man in the know. basically I need to find out what the compression levels on an rg215 should be and then have mine tested to compare the results.
Does anyone know the figure it should be?
badlydamaged
PostPosted: 13:43 - 30 Jun 2004    Post subject: Reply with quote
Its worth draining the tank and putting fresh in, just so you know the petrol isn't the problem. Between the time I crashed the bike and could ride it again water had gotten into my tank meaning it would not run well at all (sounded really sick, idling was all over the place, misfiring and when opening the throttle the bike would just die instantly), I put some fresh in and cleaned the plug and off it went again, back to its usual self.
If petrol is getting on the plug then petrol is getting to the engine and by the sounds of it flooding it. If I were you I would try and bump start the bike before you go taking it apart.
I think possible causes for it not starting are:
Ignition timing adrift, if the spark isn't at the right point in the 2 stroke cycle the engine wont run / or will run very poorly. The timing will only go adrift if its been fiddled with by someone, or if there is a fault with the ignition system (for example one of my bikes had been put together without a thrust washer, it would run when timed up but when it was put into gear the crankshaft moved from side to side allowin the timing to slip). The spark should take place at 22 Degrees Before top dead centre (BTC) @ 4000rpm according to my imformation.
Low compression: If the engine is knackered and the fuel / air charge isn'tcompressed enough the engine will not run / or will run poorly, however this is unlikely to happen over a short amount of time as compresisona only goes down as a result of wear in the engine, how many miles has it done? Compression will also suffer if the bike was seized before being sold to you, ask the previous owner if it wasn't running when you brought it. Low compression will be easy to diagnose using a compression test (speak to any local garage, should only cost about a fiver), or by actually feeling there is no compressiona when kicking it over with a kickstart (I dont think your bike will have one if it is elecy start). If it is low comporession your bike will need an ening rebuild (about £150)
Fuel system fault: as well as bad petrol, there could be leaks in the fuel system as Robby said causing a poor air fuel mixture on which the bike wont run. However it sounds to me that the bike is being flooded (petrol soaked spark plug), this could be caused by a rich fuel mixture, or over excessive use of the choke / throttle when trying to start. If it is the latter a medium speed bump start with very little throttle and no choke should bring it back to life.
This covers the Compression / Spark / Fuel requirements of the engine as mentioned by DaFrostyOne.
Also try replacing the spark plug anyway, even if it is sparking. If its trying to start but not quite making it a new spark plug could make the difference if the old one is producing a slightly poor spark. Two strokes in particular need spark plugs changing regularly as part of the service routine, and whenever I have starting problems with my bike it is usaully the sparkplug which needs replacing. The spark plug gap on your engine will either be 0.6mm or 0.7mm if its an RG FU-N.
Hope this helps a little,
Cheers, Jonathan
My bike: 1988 Kawasaki KH100 Status: Polluting Devon with two stroke smog and noise pollution!
"Its not your engine size that matters!, It's what you do with it that counts" Very Happy
Add me to MSN if you want! badlydamaged@hotmail.com.
badlydamaged
PostPosted: 13:46 - 30 Jun 2004    Post subject: Reply with quote
The factory compression for an RG125 is 8-10kgcm2, so it should be between or just under these figures if it's a servicable engine. Thumbs Up
Cheers, Jonathan
DopeB
PostPosted: 13:55 - 30 Jun 2004    Post subject: Reply with quote
you've been an amazing help
Thanks m8
thanks to everyone else too Smile
it's nice to know there are people out there willing to help Smile
I'll get to work on it tonight and let you know how it goes tomorrow
The last post was made 21 years, 177 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 58.29 Kb
